| | #1 |
| Junior Member Join Date: Apr 2008
| Rewiring input jack
I bought a BC Rich Warlock that needs a new input jack. The hot wire is only about 2 inches long and needs about 6 more inches to reach the input jack. Is there a specific type and gauge of wire that I need to splice onto the old wire or will any copper wire work? Thanks |
| | #2 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
Its in output jack. The amp has an input jack. You can use any wire you want. They often use coax shielded cable, but plain insulated wire will work.
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab |
| | #3 |
| Senior Member Join Date: Jun 2006
| | #4 |
| Member Join Date: Oct 2007
LOL...no, it's an output jack... |
| | #5 |
Ah, let's not pick on the new guy. I had one of our sales reps bring me a mic once from some school, with these instructions, "they want you to remove the XLR plug from the cord and install a 1/4" jack." It was a cheap mic with permanent cord. SO I did just that. Took the XLR plug off the cord and installed a 1/4" female. I sent it out. Oddly enough, they sent it back. I had honestly assumed they knew what they were asking for, they had used both plug and jack in the same sentence. For some reason, no one else involved found it as amusing as I did. |
| | #6 |
| Thanks!
Thanks for the replay and the correction. the guy I bought the guitar from said it needed a new input jack......so it was his fault......but it does indeed sent singnal OUT. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| MG8080RCD input jack replaccement part # | mjmiller | Maintenance, Troubleshooting & Repair | 3 | 04-21-2008 04:38 PM |
| Help troubleshoot noisey input jack | Dash_Riprock | Guitar Tech | 2 | 04-04-2008 02:55 AM |
| Loose input jack | vardali | Music Electronics | 2 | 02-13-2008 07:22 AM |
| Bad input jack? | JGR | Maintenance, Troubleshooting & Repair | 5 | 08-09-2006 12:49 AM |
| Mesa/Boogie MarkI Input Jack | Kensel | Theory & Design | 6 | 07-21-2006 02:54 AM |
