Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 04-14-2008, 09:06 PM   #1
Amp works!
My amp works!
I built a 12AX7/EL34L based guitar amp! A few minor bumps, bruises, and Lives-1, and I am victorious!
The amp is a Valve Junior clone kit with marshall gain characteristics, using an octal socket instead of a 9 pin for power tube. The diagram is for 9-pin, and the kit is designed for 6V6; an EL34 draws twice the power of a 6V6 across B+1. You can get the board and the components from WattsTubeAudio.com on the Valve Junior page.
I had to connect Pin 1 to Pin 8 (suppressor to cathode, thanks to Epiphone forums users for that tip) to rig this up for EL34; 6V6 doesn't care. I also lifted the filament grounds (filaments go through two resistors, then to ground) and instead ran them to the cathode (which goes to ground through a resistor/capacitor), and changed the input jack ground scheme.
Problem 1: I didn't center tap the 260-0-260. High voltage AC gave 520VAC, 766 rectified, and it shot sparks at me. I fixed this by using 260-0 and then taping off the other 260.
Problem 2: R10 (first resistor in power supply) handles 3W, which works for a 14W bias 6V6 (2W works here, actually). a 25W bias EL34 draws enough power to tint the resistor a light brown after 10 minutes of play, and make the amp smoke. B+2 and B+3 use the same 12AX7 so don't draw any more power. I got a 5W flameproof resistor to replace R10.
It works now. I need to put in an inline fuse and bias that EL34L hotter (I used a 2W pot instead of a 2W fixed resistor and biased conservatively), but aside from that it works quite well.
bluefoxicy is offline   Reply With Quote
My new winder. Its simple, it works, and was cheap Wrnchbndr Tools and Coil Winding Gear 10 01-12-2009 07:05 PM
Tremolo works then stops working. flyry Maintenance, Troubleshooting & Repair 1 02-25-2007 02:42 PM
zero ohms and it works? dazzlindino Pickup Makers 21 02-11-2007 12:25 AM
Tube Works MV-962 schematic needed... Jeremy Maintenance, Troubleshooting & Repair 0 01-17-2007 12:52 AM
