Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 04-17-2008, 04:54 PM   #1
Pentode/Triode DRRI?
Would It be possible to install one of these on a circut board DRRI? I'm finidng myself playing at home a lot and while this amp stills sounds pretty damn good on 2-3, I'd really like some more options!
Anyone have some info on this mod on a reissue?
Thanks,
Rick
Rick1114 is offline   Reply With Quote
Old 04-17-2008, 06:54 PM   #2
Quote:
Originally Posted by Rick1114 View Post
Would It be possible to install one of these on a circuit board DRRI?
The change in wiring would require changes to the output tube sockets, and not the pc board, so why not?
If your amp has the dummy ground switch on the back panel, replace it with a D.P.D.T. switch, and rewire the output sockets.
52 Bill is offline   Reply With Quote
Old 04-17-2008, 07:46 PM   #3
Thanks - that's the answer I was looking for. I've found the schematic for the switch - it doesn't look too difficult. Wish I could see a picture of what it looks like wired up....
Rick
Old 04-17-2008, 09:52 PM   #4
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
I don't see any problems either... however, I have always found the faux triode set up in a beam forming power tubes sounds a bit lifeless and a little dull.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 04-19-2008, 02:50 AM   #5
Quote:
You are probably right - better stick with an OD pedal for low volume dirt. I'm going to try a 1500 ohm resisitor for the NFB to reduce the negative feedback and see if that helps with pedals at lower volumes. Amp is sounding nice & spongy (i.e. no more bitey harshness) after a upgrading all the caps, but still pretty stiff compared to Vintage DR. Maybe it just needs to be played for 40 years!
Rick
SE el84 triode wired=hum as pentode=no hum ? walkman Maintenance, Troubleshooting & Repair 5 02-24-2008 03:54 AM
pentode/triode switch, is this how it's done? Regis Mods & Tweeks 4 08-26-2007 07:39 PM
Carvin Legacy Pentode to Triode Mod Ruwaldo Mods & Tweeks 6 07-21-2007 07:23 AM
12BY7A pentode or triode in a guitar amp Jelle Theory & Design 5 06-28-2007 05:40 AM
'66 Bassman triode/pentode switch? grunt Mods & Tweeks 8 04-05-2007 01:13 AM
