Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 04-17-2008, 04:19 PM   #1
stevesamps's Avatar
series heaters for 12ax7 preamp 24vac
somehow I just cant picture how to wire this?
I had this idea to use some surplus transformers
for small preamp things with 2x 12ax7
Does this make sense to do ?
run the 12V heaters in series to use the 24v winding
so pins 4 and 5 only right?
I am used to wiring them up for 6.3volts
and then I had working a doubler/tripler scheme for the
other winding..
not saving a whole lot of coin I know but
I have like 10 of these things..
Steve
stevesamps is offline   Reply With Quote
Old 04-17-2008, 05:48 PM   #2
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
other winding..
Steve
You mean you want to wire them up like this?......
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 04-17-2008, 05:57 PM   #3
stevesamps's Avatar
looks good to me
Quote:
I think I will give it a go...
Old 04-18-2008, 01:39 AM   #4
One noise-reduction suggestion - you should probably ground one of the 24VAC leads and wire the tube with the earliest triodes to the grounded side.
(did that makes sense?)
Don Moose is offline   Reply With Quote
Old 04-18-2008, 02:21 AM   #5
stevesamps's Avatar
I think so..
you mean the first and second stage if I cascade them?
I imagine I could also do a false centertap and ground that?
then again this "aint" 6.3v any more..
Steve
Old 04-18-2008, 02:51 AM   #6
A false CT good for 150mA? I dunno. (by which I mean that I do not know, not that I'm dubious of the idea)
First and second stages, yes, that's what I meant.
Hope this helps!
Old 04-18-2008, 09:15 PM   #7
Check out Peavey Classis 50 schematic. The preamp tubes there are wired this way.
Gregg is offline   Reply With Quote
Bad problem: smoke from heaters in a just refurbished amp slidincharlie (Carlo P) Maintenance, Troubleshooting & Repair 4 10-24-2007 12:33 PM
HUGE rookie mistake 18-watt heaters skip62 Maintenance, Troubleshooting & Repair 12 05-23-2007 01:57 PM
12 VDC heaters confirmation Guitarist Theory & Design 3 12-21-2006 05:49 AM
12ax7 24vac series heaters? can you... stevesamps Theory & Design 2 09-15-2006 02:09 AM
heaters gtrboy Theory & Design 1 09-02-2006 01:14 PM
