Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders > 5 E 3
Old 09-17-2006, 10:19 PM   #1
Feedback loop
Hey 5e3 builders
I was trying with a feedback loop on my 5e3 deuxe like fender did on the 6g2 model. But it does not work, it squiiiils like he.. when I connect the 56k resistor from the catode on the 2 gain state to the output.
Why is that.
Thanks
Glasstone
Reimer is offline   Reply With Quote
Old 09-17-2006, 11:34 PM   #2
Tom Phillips's Avatar
It appears that your feedback is positive. To make it negative just reverse your OT secondary leads OR reverse the OT primary leads. Whichever is easier. Then try hooking up the feedback loop again.
Good Luck,
Tom
Tom Phillips is offline   Reply With Quote
Old 09-18-2006, 01:01 AM   #3
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Out of phase is right, reverse the two leads on lugs 3 of the power tubes.... but if you try to connect this 56K NFB lead to the cathode of the first 12AX7 triode, the NFB will not work.
The cap will bypass most of it to ground.
Bruce
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Laney AOR Series II mod, fx loop, AOR gain mcrazy4fx Mods & Tweeks 12 04-08-2008 04:03 PM
SmolskiTech True Bypass Loop SmolskiTech Flea Market 4 09-13-2006 10:36 PM
delay/loop pedal Avrum Guitar Effects 0 08-22-2006 04:28 AM
5F2A With Neg Feedback Mod - Noisy!! Morgan Debugging Your Build 9 08-21-2006 11:24 PM
Kinder Anti-Feedback+ box for harp Steve A. Guitar Effects 1 08-17-2006 09:20 AM
