| | #1 |
| Member Join Date: Jul 2007 Location: NYC
| Stage 112 cuts in and out
Hey fellas, i have a fender stage 112 (solid state). when im on the drive channel, the volume drops down to nothing, and then comes back up, every time i hit a note. i cleaned all the controls, and made sure there were no cold joints....any ideas? thanks in advance! -Sam :-) |
| | #2 |
| Senior Member Join Date: Apr 2008 Location: Oceanside, NY
The most likely cause is a bad insert jack. Input jack too. Those amps are notorious for bad jacks and cold solder joints. Good luck! |
| | #3 |
Does it ONLY do this on the drove channel? Or does it do it on all channels? DO clean the power amp in jack and any insert type jacks like John says, but they wouldn't selectively affect one channel. If it is acting sorta like a crappy compressor, then I would look for some DC offset on the output pin of one of the op amps in that channel. At least for a first guess. ANd my wild guess might be a leaky mute/routing transistor - one of those JFETs.
| | #4 |
hey, thanks for the replies. yep, only on the drive channel, ill check those things out this weekend, thanks so much, ill keep you posted! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Ampeg J12T cuts out after heating up | dporto | Maintenance, Troubleshooting & Repair | 34 | 12-22-2007 02:32 PM |
| Ampeg J12t cuts out | Marc | Maintenance, Troubleshooting & Repair | 6 | 12-11-2007 09:01 PM |
| Champion 600 (basically an AA764 circuit) cuts out | khelstrom | Maintenance, Troubleshooting & Repair | 8 | 10-18-2007 08:44 PM |
| Twin Reverb build cuts out when Volume all the way up | nicksorenson | Debugging Your Build | 6 | 05-20-2007 03:34 PM |
| peavey 300 cuts out | stefan | Maintenance, Troubleshooting & Repair | 1 | 03-27-2007 02:10 AM |
