| | #1 |
| Member Join Date: Oct 2006
I have an old amp that had a 6AU6 preamp pentode, and it sounded completely amazing, though very noisy. I had swapped that tube out for a 6BA6, which sounded similar with a little less noise. Then, I found something interesting: a 6BE6. It is a seven-pin heptode, which I found had a pinout and specs which would allow it to be directly swapped with the pentodes. I tried it of course, and it sounded even better in my opinion, and the amp is now dead quiet! I have never heard of that being done, so I just wanted to pass on that tip to anyone who may be interested. |
| | #2 |
| Senior Member Join Date: Jul 2006 Location: Goteborg, Sweden
That's analogous to strapping pentode as triode. Heptode strapped as pentode. How did you wire grid 3?
| | #3 |
| Lifetime Member Join Date: May 2006 Location: Wise, Virginia
If you like your current result try using these bottles to mix two signals - much more elegant than the junction of two isolating resistors. Better yet try a 6L7 - if the grid cap isn't off putting - specifically desinged for audio work as a mixer/control tube. Rob |
| | #4 |
Alex, grid 3 is jumpered to the cathode. I've never used a heptode before, so I didn't know what else to do with it. I guess it's supposed to be a second control grid, but I am unsure as to how I could use that beneficially. Wire it to grid 1? Rob, that's a good idea. I haven't had any reason to mix two signals yet, but I'll keep that in mind. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Mod a Preamp | guitarkirkster | Mods & Tweeks | 2 | 04-01-2008 04:05 AM |
| Preamp too loud | Hallingamp | Theory & Design | 3 | 01-13-2008 02:24 PM |
| hafler t2 preamp | slagg | Maintenance, Troubleshooting & Repair | 5 | 12-22-2007 07:14 PM |
| Amp Tubes / Using Preamp out | silentbry | Maintenance, Troubleshooting & Repair | 11 | 02-10-2007 06:33 PM |
| ADA preamp | brewu22 | Maintenance, Troubleshooting & Repair | 1 | 11-18-2006 08:03 PM |
