Power Tube Sockets ! Did you change the power tubes ? Do you see an arch when your playing ? The popping is most likely the 6l6's arching at high voltage and will not produce a good tone if any when this happens. Try pulling two tubes and see what happens but you should be able to see it happening. If not I would strongly think tube sockets.
LinkBack URL
About LinkBacks
