Results 1 to 2 of 2
Thread: Plate Voltage Fluctuating
    NYC
    1,478
    Retubing a 5E8 Twin clone for somebody,check the plate current on the old tubes and see 372vdc-57ma.Got sidetracked and when I got back to it an hour later I check again and I am seeing 410vdc with 64ma,6L6GC tubes by the way.Investigating further I see that most times on power up the plate current and volts start high and slowly drop about 50-75 volts.At times on power up it will just read steady,sometimes as low as 345 or so and as high as 430v,but most times I get the high to low drift. Checked for shorts with a light bulb in series and also a volt/wattmeter and it doesnt have any shorts.Tried the new tubes and I get the same fluctuations.The silver flashing on the old tubes is turning brown,so I assume they were redplating when it was running at the higher volt/amps.I am thinking it is a problem with the bias supply and will check that,but wanted to see if anybody here has any ideas.Thanks.
    NYC
    1,478
    It was a bad rectifier tube.
  1. Using 1r to measure plate current
    By loverocker in forum Theory & Design
    Last Post: 08-23-2006, 08:41 PM
  2. Ideal 2xEL84 plate voltage
    By Matt T. in forum Theory & Design
    Last Post: 08-21-2006, 02:50 PM
  3. back plate shielding system
    By scorpio in forum Pickup Makers
    Last Post: 08-18-2006, 04:16 AM
  4. 5E3 Voltage problems
    By Watto in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-21-2006, 12:50 AM
  5. Plate voltage and OT impedence of the 5E3?
    By Satamax in forum 5 E 3
    Last Post: 07-03-2006, 11:33 PM
