| | #1 |
| Senior Member Join Date: Jun 2007
| vox super beatle schem
anyone know where to find a schem for a super beatle? got one w/ broken reverb.
| | #2 | |
| Old Timer Join Date: Jun 2007
| Quote:
Check the tank first. Depending upon the model and year, it could be a 8 ohm input or a mid-impedance input tank. I've also seen a lot of problems with the molded RCA plugs on the wires to the tank. The reverb also switches to the different channels on the back. I've seen those switches cause problems as well. | |
| | #3 |
i don't see a model # anywhere... could it be inside? Any other markings or do I need to open it up?
| | #4 | |
| Quote:
If the back plate is missing, there really is only one difference in the reverb circuits in all of the model that I have seen, and this is true of all of the amps that share the similar pre-amps-Viscount, Buckingham, Royal Guardsman and Beatle; one has a transformer driven reverb tank and the other has a transistor amp driven reverb tank. This is why there are two versions of reverb tanks in these amps, one has an 8 ohm input and the other a mid impedence input. Is the reverb completely dead? If you jiggle the tank can you hear the springs boinging through the speakers? Is it dead through both channels or does it work in one of the two? If the tank has been replaced, is the input RCA jack ground isolated or not? These amps need the input jack to be grounded, as the drive wire is not a two conductor wire. | |
| | #5 |
| Member Join Date: Jul 2006
VOX Super Beatle V1141 schematics
| | #6 |
thanks! 52 Bill I no longer have the amp in possession but will track down customer to ask him for it... thanks.
| | #7 |
| Junior Member Join Date: Dec 2008
Hi. Does anybode have any idea about all the transistors used in V1141??? Thank you in advance. |
| | #8 |
| Senior Member Join Date: Jun 2006
| | #9 |
| | #10 |
| Lifetime Member Join Date: May 2006
If I remember correctly, all of the transistors with the exception of the reverb tank driver and the phase inverter transformer driver in the power amp can be replaced by any low noise NPN small signal transistor with gain over about 200. My favorite NPN, the 2N5088, can be used for essentially all of them, as can most other NPN low noise devices. The only uniqueness is where there is too much power or current for these small devices to handle. See "Bulletproofing your Thomas Vox Amp on my web site for more practical service info, especially discussions on replacing the output transistors. |
| | #11 |
Thanks, but I am interested in original transistors. Any ideas??
| | #12 |
Hi Jimmy, welcome to the forum. RG actually knows quite a lot about these amps, you might consider his suggestion. CHanging transistors is not like changing a 12AX7 for a 12AT7 or something. Transistors are remarkable flexible. Not sure where you will find those 2N2926s. I checked Mouser/Allied/Digikey, and others and closest I came was Mouser suggesting a BC184L as a cross. From the original parts list, there are these numbers - Vox part numbers. In the 100 section, all transistors are 86-5044-2 In the 200 section, most are 86-5044-2, except these: Q201 86-5050-2 Q202 86-5075-2 Q211 86-5064-2 In the 300 section (power amp): 86-5084-2 output transistors 86-5085-2 driver 86-5050-2 input transistor. perhaps that will help If you know anyone who services organs, see if they have a "HAB" guide. Thomas used the same part numbers in their organs, so they might be able to look up the crosses in that.
| | #13 |
| Senior Member Join Date: Jul 2006
This post about a vox waa may help. http://www.freestompboxes.org/viewto...d=a&hilit=5117 eg 86-5044-2 ORDER 71226-015, TRANSISTOR, NPN 2N2925 well a few clues |
| | #14 |
| Junior Member Join Date: Jan 2009
| anyone know how to identify which vox head i have
i think its a beatle or super beatle...it has the percussion knob and a slide switch for the "e" tune...i dont see these on the beatle,just the super beatle...any help is much appreciated..thanks tom
| | #15 |
Hi tom, your vox head with percussion knob and "e" tuner may be Vox Series Ninety V133. This head "come" with Vox Booster Amp V836. |
| | #16 |
| vox head
thanks...the head cabinet its in looks like the beatle head and the control knobs are all in a row...but the info you sent does have all the same features..thanks, tom
| | #17 |
| Junior Member Join Date: Dec 2009
It never rains, and then it pours, WOW !!!! God just blessed me with two MORE things----YOU, and an entire V1141 schematic !!!!!!! Thank you so much for posting this. Born in '46, you are helping me not to forget the "FAB" times of my youth. In '64, I was in the USAF, and playing off-base with two British Invasion type bands. I still don't know how (in one felled swoop), the whole band managed to clear a 4' chain link fence with all our gear in tow in a succesful attempt to avoid prosecution for "disturbing the peace" of an apartment complex ???? Anyhow , thanks again, and by the by, do you know where one might obtain plans for the V1141 head cabinet ??? God's blessings to you and yours, and a very merry Christmas indeed!!!! Beatle Geo
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Need layout & schem for new DIY amp | MickeyB | Theory & Design | 10 | 01-27-2008 07:19 AM |
| need Sampson SS schem. | drewl | Maintenance, Troubleshooting & Repair | 4 | 11-08-2007 10:46 PM |
| Dynacord DA 15/V schem | Snapcase | Vintage Amps | 4 | 07-03-2007 04:40 PM |
| schem for Ampeg BA-115 | JC@ | Maintenance, Troubleshooting & Repair | 1 | 09-20-2006 12:44 AM |
| Marshall TSL FS schem? | drewl | Maintenance, Troubleshooting & Repair | 0 | 08-18-2006 04:22 PM |
