Old 05-23-2008, 01:04 AM   #1
JCM900 - urgent advice needed
Hi all, Ive got a 4500 model (head) I'm getting intermittent volume drops and can't figure out what's happening...
This model has a separate master volume for each channel but its happening on both which says to me it could be the power amp stage...
had a look at the valves (marshall branded EL34's for those who care) they're all glowing happily, Ive run it at 25 watts and tried 1 valve at a time,
tried with different leads, tried cleaning the pots and checked the entire thing for dodgy soldering/connections, tried wiggling leads at i/p n o/p, different cabs etc
I'm stumped and have an v important gig in about 21 hours or so and my only backups are a pod xt live through the PA or my mate's valvestate - nuff said eh?
On the plus side though its not half as bad once she's warmed up a bit but I can't gig it in that state - any advice/diagnosis???
Kermit is offline   Reply With Quote
Old 05-23-2008, 01:22 AM   #2
Garydean's Avatar
Do you have an effects loop? Try jumping that with a cable and see if that clears it up. If so, those jacks could need some cleaning.
Garydean is offline   Reply With Quote
Old 05-23-2008, 01:27 AM   #3
Quote:
What he said......
Gtr_tech is offline   Reply With Quote
Old 05-23-2008, 01:55 AM   #4
Genius! cheers Theres a load of gunk on the send socket, bridging seems to help so I'll pick a new 1 up tomorrow
1 more prob though... theres a fx level dial which peaks halfway in between high and low then drop either side... don't suppose ya know if thats normal or whats causing it?
Advice needed about Ebay sale I did Regis Lobby 25 04-06-2008 05:08 AM
Buying a variac: advice needed slidincharlie (Carlo P) Maintenance, Troubleshooting & Repair 1 01-20-2008 10:37 PM
beginners luck advice needed ampdummy Maintenance, Troubleshooting & Repair 10 05-07-2007 02:34 AM
Old tubes - please advice needed (6SC7, 6J7) slidincharlie (Carlo P) Tubes (Valves) 16 01-25-2007 12:10 AM
Signal Generator Advice Needed bob p Music Electronics 10 01-24-2007 07:56 PM
