Results 1 to 30 of 30
Thread: Measuring inductance with standard multimeter
    Feb 2008
    France
    89
    I have a standard multimeter with an (supposedly) inductance meter position.
    However I cannot get the inductance of any pickup with this. I believe this is "normal" since this is true for any pup I've tried to get the value.
    Could someone give me the clue why this ? I suppose I'd need a proper LRC meter for this task, right? (But why then having an inductance meter on the multimeter if useless...is this just a crappy tool?)
    Thanks,
    Yves
    Supporting Member Dave Kerr's Avatar
    489
    Old Timer Possum's Avatar
    Planet Mongo in the country of PAF
    3,953
    It probably doesn't have a proper test signal, for pickups you need 1khz and 120hz. I was just looking over some cheap inductance meters and they have a 20khz test signal, totally useless for pickups. Yes you should be a good LCR meter, the Extech is good because it has those two test frequencies plus it also measures AC resistance which I find really useful. They're not cheap but oh well, what is.....
    http://www.SDpickups.com
    Stephens Design Pickups
    1,310
    also, might be beyond the range of inductance it can read
    Feb 2008
    France
    89
    Thanks for the info, all of you.
    BTW, and having read Joe Gwin's explanation, I am surprised to learn that a B&K meter would not do the job :I would have expect such meter to be a reliable tool (in any situation).
    So Extech is on my list now when I have the money for it.
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,945
    You still need the VOM though, so it wont go to waste.
    It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. Albert Einstein
    http://coneyislandguitars.com
  7. #7
    Feb 2008
    France
    89
    Cheap LCR meter
    I've just bougth the Elektor issue of June: there is an very simple, cheap LCR meter using a PC sound card.
    I cannot reproduce the article here for obvious copyright reason, but you've got the info for those of you who are not equipped with this tool, if you want to buy the issue.
    Altenatively, here is the link to the article:
    http://www.elektor.com/magazines/200...0.495109.lynkx
    I think that if you register, you get 10 units free credits (at least this is the case in the FR site), which is just enough to download the article in pdf.
    I have not tested it yet since I need to buy one IC for this first (need to find the time), so now feedback for the moment ...
    Yves.
  8. #8
    Boston, MA area
    2,602
    Quote Originally Posted by Yves View Post
    And flood one with valuable free offers.
    What is the basic measurement being made? This will help tell if the instrument can handle pickups, which have a large amount of DC resistance in series with the inductance. Most LCRs give wildly wrong answers on pickups.
    My guess is that this sound-card based instrument will not work well with pickups for a very fundamental reason: sound cards ignore phase and measure only amplitude. For a sound card, this is reasonable, because the human ear does not sense phase either, and certainly does not care about relative phase between input and output.
    To measure LCR, phase is essential unless the component being tested is very "pure" (so one letter always predominates). But in pickups, the R and L have about the same reactance at the frequencies of interest, and thus are quite impure.
  9. #9
    Boston, MA area
    2,602
    An afterthought. If you have the PC sound card, you can use it to drive a Maxwell Bridge.
    http://home.comcast.net/~joegwinn/
    This can be very accurate, and will work at any frequency, but is slow to use. I used this bridge to validate the Extech, to prove that it gave full accuracy on real pickups.
    If you will measure many coils, get the Extech.
  10. #10
    Supporting Member
    Jun 2008
    Italy
    1,139
    Talking If available, check out a Lutron
    Hi,
    for LCR measurements I purchased a Lutron LCR meter, it' s reliable, quite accurate and it could fit the bill without hurting your wallet that much; what' s best, it reads inductances up to 20 H, way over the hottest imaginable overwound pickup, and the capacitance meter goes up to 2000 mF, so I also use it to sort out caps on tube amps' PS filtering sections. I got it for about 100 Euros, check if this brand is available in your area.
    Regards
    Bob
  11. #11
    Senior Member salvarsan's Avatar
    Jan 2008
    The pines country.
    1,107
    smiling phases
    Quote Originally Posted by Joe Gwinn View Post
    We sense ear-to-ear differential phase best when the full wave length is roughly the length of our ear canal. Absolute phase is, of course, impossible.
    -drh
  12. #12
    Boston, MA area
    2,602
    Quote Originally Posted by voxrules! View Post
    Hi,
    What's the exact model number? I'd like to look it up.
  13. #13
    Boston, MA area
    2,602
    Quote Originally Posted by salvarsan View Post
    But...but...between ears is between inputs....
  14. #14
    Jan 2008
    The pines country.
    1,107
    I merely wanted to point out that the auditory mechanism by itself does interesting preprocessing.
    Those three bones that couple the drum to the cochlea perform a rough differentiation and half-wave rectification before the signal ever gets to the cochlea.
    ...then there's all that pre and post compensation that the limbic system adds.
    Oy.
    Wish there was a calibration run that we could do on ears
    before we start yakking about pickup timbre.
    If there was more money in it, pickup making would have what
    Emile Peynaud types and UC Davis did for wine.
    -drh
  15. #15
    Boston, MA area
    2,602
    Yes. I read up on how bat sonar works some time ago. Very interesting - some species of bat do fixed-frequency pulses with doppler processing (to detect tiny movements despite obscuring vegetation) while other species use linear-chirp signals and pulse compression (to achieve very high range resolution and the ability to see very small targets far away). These are called CW (continuous wave) and FM (frequency modulation) respectively.
    Present-day radars and sonars do almost exactly these things. The biggest difference is that radars and sonars are phase coherent, where the received signal is compared in phase with the transmitted signal. No animal does this.
    However, bats anticipated the development of radar and sonar in WW2 by 60 million years.
  16. #16
    Staten Island, NY
    10,945
    Generally yes, this is true. But some people can hear the difference (I used to, but I haven't tried it in many years, so my hearing is probably not up to it anymore, and I couldn't tell you what I heard different. But I did.)
    It seems that the high frequency stuff we assume is outside our range of hearing is a lot of phase related information, which might help us detect where things are around us by sound reflections.
  17. #17
    Boston, MA area
    2,602
    Quote Originally Posted by David Schwab View Post
    It is true that we can sense phase differences between ears (at least at low frequencies), and this is used to determine the direction of the sound source. As is differences in intensity between ears (at higher frequencies).
    However, we have drifted a bit. My point was that sound cards are typically not equipped to measure phase between output (to speaker) and input (from mic), because it isn't generally needed, and that this lack of phase information will prevent a sound card from making some kinds of inductance measurements.
    But I bet there are industrial sound cards that are sensitive to phase. The giveaway would be a card that yielded I and Q (in-phase and quadrature) data on its input signal. A two-channel card could measure phase in and phase out, plus test signal frequency, from which one can calculate RLC as for a handheld meter.
    I bet the Extech is cheaper than that industrial sound card. The advantage of the industrial card would be that one could work at any frequency.
    This happens too. There is a lot of research going on into how we can tell the elevation of a sound source, and the basic answer seems to be that we sense the delayed replicas of the source signal, the amount and pattern of the delays being the clue. The schemes I've seen are very complex; perhaps someone will find the simplicity within, but it hasn't yet happened.
    Our ability to hear transients (like attacks) seems to well exceed the 20-20000 Hz bandwidth one gets by testing the young with sinewave tones, so I would design for response out to about 50 KHz.
  18. #18
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    How about looping the output back to one of the inputs of the sound card? Then all it needs to do is measure the difference between its left and right inputs to get phase difference, or indeed a complete transfer function analysis.
    There's a program called Spectrum Lab that can do I and Q measurements with any sound card. It just runs in stereo and assumes one channel is I and the other is Q. I used it to demodulate shortwave radio with a home-made Tayloe detector. I doubt that it measures inductance, but it proves that you can do things with phase...
  19. #19
    Feb 2008
    France
    89
    Most probably, but you don't need to use your primary email account for this purpose.
    That's pretty much the principle here: one channel input is used as a reference, the other used for the measure, the output feeding the signal test (1000, 1250 or 2200Hz, which makes me think it should be usable for pickups).
    AND it does test both amplitude and phase.
    It's just silly as the fact that I don't have any spare minijack with me to run test at the moment (because there is also a way of using is with no IC buffer at all), and I don't way to dismantle some headphones for this...
    I'll let you know (for those who are interested) how it does the job. I am personnally not looking for a precision lab tool at the moment but something to compare different pups or for trouble shooting.
    No doubt an Extech is far more handy and reliable, but if this works as is, it would just be fine for me.
  20. #20
    Supporting Member
    Sep 2007
    2,992
    Thanks,
    Yves
    Rather than attempt to measure the inductance directly, why not measure the resonant frequency with a typical amount of capacitance across the pickup? You need hardware and software on your computer so that you can output signals (I use random noise.), and you need an input and software to measure a power spectrum and accumulate over many passes to give good accuracy. I use a one meg resistor in series with the sound output so that you have close to a current source and measure the voltage across the pickup, using a high impedance preamp before the computer input. You can add capacitance across the pickup so that the total (cable + preamp input + added C) is a few hundred to 1000 pf to simulate actual conditions. (Or just use an actual guitar cable. You can measure its capacitance sort of accurately with you multimeter.)
  21. #21
    Boston, MA area
    2,602
    The problem with using the left and right channels of a sound card is that they may not have time-aligned the sampling instants in the two channels. True I&Q requires that the samples be taken at the same instant in both channels.
    That said, if one samples way faster than the signal, time misalignment isn't that much a problem.
    Do these sound cards have four input channels? One needs two channels for I&Q of input to the pickup under test, and another two channels for I&Q of the output.
  22. #22
    Glasgow, Scotland
    7,251
    Any half decent sound card should have time-aligned channels, otherwise it would have a lousy stereo image at high frequencies.
    I have a M-Audio Delta 1010 in my home recording setup, so I'm never short of inputs and outputs
  23. #23
    Supporting Member
    Jun 2008
    Italy
    1,139
    Lutron LCR meter
    Hi Joe, the model number is LUTRON 9073
    Regards
    Bob
  24. #24
    Supporting Member
    Jun 2008
    Italy
    1,139
    Cool A simpler way to determine pickups' specs
    I have developed a simpler way, a variable frequency sinewave generator and an oscilloscope will suffice.... here it is :
    Salvage a relay with a small DC resistance coil ( and little inductance ) , and tie it to the signal generator, then hook the pickup ouput to the oscilloscope.
    Start generating a signal and put the relay coil near the pickup under test - the sinewave will appear on the oscilloscope, so adjust the scope and the signal source for optimal measurement/visibility ....measure the amplitude, ensuring yourself the distance between the relay coil and the pickup poles remains constant - then simply increase the frequency measuring the amplitude as you go up, you' ll be able to determine the resonant peak, the Q factor and the bandwidth, which are determined by LC ( resonant peak ) and RLC ( Bandwidth - Q ). You can also evaluate the pickup' s behavior with a load connected ( real-world ) simulating an amp' s input circuit with a RC network, and also take into account cable capacitance ( added in parallel to the pickup' s output, say 100-120 pf/mt.
    The low resistance, low inductance and equally low parasitic capacitance of the relay coil will ensure you accurate readings, it is true that they will generate a second resonant peak but since this will be located at a much higher frequency, it will not spoil your readings.
    Hope this helps
    Best regards
    Bob
  25. #25
    Boston, MA area
    2,602
    Found it. Thanks. There is no mention of allowed Q ranges, or any way to select the series or parallel arrangement of inductance and resistance, so I'd worried that this instrument assumes pure inductances, and will not do well with impure inductances such as pickups.
  26. #26
    Supporting Member
    Jun 2008
    Italy
    1,139
    Hi Joe, that' s true, but I have verified the readings using the method I described in my last post, and they matched almost exactly.... since a pickup can be modeled as an inductance with a resistance in series and a capacitance in parallel, I measure R and L separately, then I apply a guess ( which has proved to be fairly good in several cases ) of assuming a parasitic winding capacitance of about 110 Pf for a 6 KOhm winding, measure the DC resistance of the pickup under test and estimate the parasitic capacitance accordingly; when verifying with the generator and oscilloscope, the actual resonant peak, Q and bandwidth were where I expected them to be....very close or matching with the calculated ones.
  27. #27
    Boston, MA area
    2,602
    This is pretty indirect, and is affected if the AC resistance differs significantly from the DC resistance, which is often the case.
    DC resistance is what one measures if the test signal is DC, which is what ohmmeters do.
    AC resistance is measured using an AC test signal, and is the AC voltage divided by the in-phase (with the imposed AC voltage) AC current.
    AC resistance is not reactance. Reactance is the AC voltage divided by the quadrature (with respect to the imposed AC voltage) AC current.
    The inductance causes the reactance, while the DC resistance is the DC resistance plus eddy-current loading.
    The Extech measures and reports both reactance and AC resistance.
    It isn't clear what the Lutron 9073 does, but a typical approach (for pure inductances and capacitances) is to measure AC voltage and resulting AC current (the current being the vector sum of the AC resistance and reactance), and assume that the measured AC current is entirely due to reactance. This works well enough for ordinary electronic components, which are pretty pure electrically.
    What also works quite well is a Maxwell-Wein Impedance Bridge, which despite the big name is simple and cheap to construct from ordinary radio parts, and measures AC resisance directly. Bridges were the mainstay of national standards labs for a good century, partly displaced only by the rise of digital instruments.
    Here is my report: http://home.comcast.net/~joegwinn/.
  28. #28
    Supporting Member
    Jun 2008
    Italy
    1,139
    Joe, all you stated is absolutely correct, I just wanted to point out that it is possible to get a pretty good idea of a pickup' s behavior using fairly cheap equipment and a little of experience....
    Best regards
    Bob
  29. #29
    Feb 2008
    France
    89
    Joe, you were right: this setup lead me to nowhere (weird readings).
    However, regarding the soundcard, I am convinced that nearly any card on the market has left and right channels of stereo inputs time aligned, or this would be a faulty design really. I can understand that multitrack digital systems may have time alignment issues depending of DSP load or plug-ins inserts, but stereo inputs must have both channels time aligned.
    Besides the lousy stereo image that Steve mention, in the event of for instance a consumer that uses the card to capture a "fulltrack" mono (from say some old VHS for archiving), time misalignment would end up with nasty comb filtering. I guess most of the card are designed around integrated codecs that are time aligned.
    Back to the RLC thing, I've bought this:
    https://www.conrad.fr/pont_rlc_porta..._217179_217180
    I believe this is the similar to the Extech (similar specs and look), and it is quite a handy tool indeed.
    It was 35% off the price a few days ago: for anyone interested in ordering from Conrad, just Google "Conrad code promo" first and you most probably find some kind of special discount/offer (they always have some).
    Thanks to all anyway for the advices on the measures.
  30. #30
    Boston, MA area
    2,602
    Bullet dodged.
    The R and L channels need time alignment only good enough to fool a human.
    However, sound cards must sample fast enough to handle 20 KHz, so the misalignment probably isn't going to cause big problems for measurement of pickups at 1 KHz. I would just try it.
    Pont's website had useful information. To my eye, the Pont 4080 appears identical to the Extech. Probably comes from the same factory in Taiwan.
    There is something else - the circuit diagram. It is as I had expected, being an "IV" design. The Plus terminal is driven by a voltage source, and the Minus terminal feeds a opamp transimpedance amplifier (which has ~zero input impedance and converts incoming current into voltage). It is easy to home-brew such things, and such a circuit could be wedded to the sound card, with the left channel measuring the imposed voltage and the right channel measuring the resulting current (as converted to a voltage by the transimpedance amplifier).
  1. can you recommend a multimeter?
    By mike_mccue in forum Music Electronics
    Last Post: 05-06-2008, 03:35 AM
  2. inductance and scatterwind..
    By SteikBacon in forum Pickup Makers
    Last Post: 05-01-2008, 05:08 AM
  3. Inductance
    By Paulkstadden in forum Pickup Makers
    Last Post: 02-26-2007, 04:49 PM
  4. Inductance vs Ac Resistance?
    By jimi in forum Pickup Makers
    Last Post: 09-16-2006, 01:45 PM
  5. Measuring PTs
    By MitchK in forum Theory & Design
    Last Post: 08-18-2006, 07:02 PM
