Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 06-06-2008, 10:59 AM   #1
Volumen pot position in cathode follower design
Hello!
I,m gonna mod the Normal channel of my AB763 clon adding a cathode follower tonestack.
My design is like this:
imput---cathode follower---tone stack---volumen---gain stage---gain stage---P.I.
Could this work, or should i move the volumen pot and insert it betwen the cathode follower and the tone stack?
imput---cathode follower---volumen----tone stack----gain stage---gain stage---P.I.
regards from Spain!
chocopower is offline   Reply With Quote
Old 06-06-2008, 10:35 PM   #2
Either configuration will work, but the first will give a more consistant tone control operation across the range of the volume control. The output impedance of a 1 M ohm volume control will vary from 0 - 500k ohm, which will alter the turnover frequencies of any RC filters (ie tone contols) which follow it.
Better for the low output impedance of the cathode follower to feed the tone stack.
You have the potential for a lot of gain in your design (assuming you're using 12AX7 tubes) , you might need to trim it back. Peter.
pdf64 is offline   Reply With Quote
Old 06-07-2008, 01:21 PM   #3
Thanks!
I,m testing a mod i saw time ago in Blueguitar.org.
In this mod the 12at7 reverb driver is de-paralelled and the free half is use as gain stage. This mod is explained in 2 channels, with reverb, Fender amps.
The 2 first gain stages are wired as a cathode follower and the 1/2 12at7 push the signal ater the tone stack.
regards from spain!
Old 06-10-2008, 02:28 PM   #4
Quote:
Originally Posted by chocopower View Post
Hello!
regards from Spain!
I would favor the first configuration as well. Not so much for any changes in the respoces curves, but more importantly the reason one would use a CF to drive a tone stack. A CF is a current amplifier, used to source current to charge the capacitance inside the stack, thus improving the slew rate. If you insert a pot inbetween the CF and the stack, you just nulled out your source current. Does that make sense ???
-g
__________________
Gary Moore
Moore Amplifiication
mooreamps@hotmail.com
mooreamps is offline   Reply With Quote
Old 06-10-2008, 04:50 PM   #5
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Quote:
Originally Posted by mooreamps View Post
... used to source current to charge the capacitance inside the stack, thus improving the slew rate. If you insert a pot inbetween the CF and the stack, you just nulled out your source current. Does that make sense ???
-g
I don't know about that. Doesn't that term "CHARGE" imply that the caps (I assume you mean the three tone coupling caps) are "charged" with a DC source? Which of course does not happen.
I think the big difference is that the tone stack's natural total impedance is 25 to 35 times higher then the cathode follower so the stack has nearly no loading effect on the CF.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 06-10-2008, 07:59 PM   #6
Quote:
Originally Posted by Bruce / Mission Amps View Post
I don't know about that. Doesn't that term "CHARGE" imply that the caps (I assume you mean the three tone coupling caps) are "charged" with a DC source? .
No Bruce, charged from an AC current source, from a lower source impedance.
-g
__________________
Gary Moore
Direct input to a cathode follower chocopower Theory & Design 0 05-09-2008 05:09 PM
What is a cathode follower? bluefoxicy Theory & Design 10 04-25-2008 11:26 AM
Adding a cathode follower shef86 Theory & Design 8 04-09-2008 01:33 AM
How many stages in front of the cathode follower? rexindigo Guitar Amps 7 11-13-2007 11:29 AM
Cathode follower cathode resistor question Mark Buckingham Theory & Design 9 10-10-2006 12:12 AM
