| | #1 |
| Senior Member Join Date: Jul 2007 Location: Indianapolis
| Building a Portaflex - PT, OT, cab?
Hey, fellas. I'm getting lined up to build me a Portaflex, probably a B15N, but single channel. I have some suspicions about what iron (PT and OT) to use, but I'd like suggestions - it's a 2x6L6 power section in a bass amp. If anyone has cab dimensions for the 15", and maybe speaker brand/model suggestions, they'd be welcome as well. Thanks! |
| | #2 |
Fliptops.net seems to have most of what I need - except a chassis.
| | #3 |
| Member Join Date: Oct 2006
The original speaker was a Jensen P15N, which sounds quite nice in there. If you need any dimensions, let me know.
| | #4 |
Please, yes - whatever you have. There isn't much documentation ... at least not that I've seen. Thanks! |
| | #5 |
Let me rephrase that - Chassis size, knob/jack spacing, locations of chassis mounting bolts (if convenient). I sort of think I'll buy the cab from Fliptops. Thank you! |
| | #6 |
Since this is a bass amp, I'd think I need a rather beefy OT. Would a HiWatt unit from Heyboer/Mercury/Weber be a good choice? I may go 100W while I'm at it. |
| | #7 |
| Supporting Member Join Date: May 2006
Oh, I thought that this was about building a Porta-Potty! Sorry about that... I think it should clean right up with a little Lysol. Steve Ahola |
| | #8 |
I will try to compile and post all that as soon as I can. I've got a '68 B15N in my bedroom. The only proper Portaflex iron I've seen is obnoxiously overpriced. Unfortunately, it's also the only iron that will look right without modification. I would probably fabricate covers for the transformers that look like the original covers. The real ones don't seem all that big for a 30-watt amp. Transformers for a Bassman would certainly work electrically, although I'm not sure if the dimensions would allow them to be covered like the Portaflex trannies are such that they would work cosmetically. How would you do a 100 watt Portaflex? There's certainly no room for two extra 6L6's. I suppose you could use two KT88's at 600VDC, but you would then need expensive iron which would be too big to fit on a chassis of original size. |
| | #9 |
Ampeg's reissuing the B15 as a 4x6L6 100W product, and 30-50 seems a little light. I have been playing with some tubes-n-iron layouts and thinking a HiWatt style format (output tubes across the back between trannies, preamp and PI tubes across the front between tagboard and pots) might work. Fit is more important than cosmetic correctness right now, but we'll see where this leads. The plans haven't solidified yet, but the more information I start with, the ... less stupid I can be about my options. Whatever notes I get from you I will try to turn into drawings for general sharing purposes. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| 2X12 Cab, need help | CattMallahan | Build Your Amp | 1 | 05-23-2008 02:38 AM |
| No Sound Out Of Cab...Help! | oceantracks | Maintenance, Troubleshooting & Repair | 2 | 09-29-2007 03:20 AM |
| How old is my Portaflex? | drummerfish | Vintage Amps | 3 | 09-18-2007 08:28 PM |
| building a cab...for a Bandmaster | benindavis | Vintage Amps | 1 | 07-04-2007 12:16 AM |
| my new cab | John_H | Cabinetry | 18 | 09-04-2006 12:36 AM |
