Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 06-19-2008, 07:39 PM   #1
best post PI master volume
Any opinions on what the best post phase inverter master volume is? Right now Im using one seen in matchless chieftan amps, with one PI output connected to an outside lug, and the other output connected to the wiper. Pretty cool stuff, just wondering what others think...
EETStudent is offline   Reply With Quote
Old 06-20-2008, 12:47 AM   #2
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Quote:
I don't like it at all... that's what I think. The best one to me is the dual gang 250K to 500K MV pot... wired either backwards or like a volume control and DC blocked to keep any DC off the pots and DC -V Bias where it should be.. on the power tube grids.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 06-20-2008, 07:56 AM   #3
If you have FDB from the OPT to the PI think what happens when the signal going back gets lower but the signal in to the PI stays the same. When you turn down the post PI volume the the PI will get less feedback and will amplify and distort more.
Tubis is offline   Reply With Quote
Old 06-20-2008, 08:16 AM   #4
Well, I dont have any negative feedback. I had tried a couple things before this post, and Im with you Bruce I dont much care for it I guess.
Old 06-20-2008, 02:53 PM   #5
Quote:
I agree with this design being the best. The best way to implement that I've found is to use a dual 250K pot, and use the resistive element as you bias divider, in place of the ubiquitous 2 x 220K resistors usually used, OR run them to ground if using cathode bias. Then the wipers are connected to the PI coupling caps. In this manner, you maintain bass response when turning down the MV. With the single-pot setup, you load the caps too much.
__________________
John R. Frondelli
jrfrond is offline   Reply With Quote
Old 06-20-2008, 03:33 PM   #6
hasserl's Avatar
Quote:
ISn't that why most people use a MV? To get more distortion at reduced volume levels? What's the problem? I see people post on this all the time and I just don't get what the problem is. I've installed dozens of post PI MV's in amps with nfb, and it's never been a problem, not once.
Well, other than the reduction in Presence or other controls in the nfb circuit. But that I can live with as a trade off for the sonic benefits the post PI MV gives.
As for the single pot "crossline" style MV, I've used it on several amps with good results; I've used it on others with horrible results. My conclusions are it depends on the particular amp you're using it on and it shouldn't be written off universally. I've also used the type Bruce mentioned above, with the dual pot isolated from all dc with four caps, and the "Ken Fisher" style which replaces the two 220k bias mixing resistors. I think the KF style has the best sonics, the isolated four cap version is very close sonically but it is safer in that you don't rely on the pot wiper to carry the bias voltage. The crossline, when it works on an amp, works best at just scrubbing a few db's off the volume, not so good at bringing the volume all the way down to bedroom levels.
hasserl is offline   Reply With Quote
Old 06-20-2008, 04:41 PM   #7
MV pot connections
Quote:
If the wipers are connected to the caps, then as volume is turned down, the load (and bass response) would go down also.
I think the wipers are supposed to be connected to the output tube grids, not to the coupling caps. The connections on the pot opposite the common connection to ground or bias go to the coupling caps.
Russ is offline   Reply With Quote
Old 06-20-2008, 08:31 PM   #8
Yes, you are correct sir, as I look at the schematics for one of my own amps. That's what I get for doing late gigs on weeknights!
__________________
John R. Frondelli
Old 06-20-2008, 09:11 PM   #9
There's a varient of the KF PPIMV popular over at the Metro Amp forum. It's basically the KF design with safety resistors added between the wiper and output lug on the dual pots. If the wiper should give out, the resistors see to it that bias voltage is maintained to the tubes.
I've installed it in two amps with good results and plan on installing it in the Heathkit rebuild I'm doing.
CitizenCain is offline   Reply With Quote
Old 06-21-2008, 08:38 PM   #10
No problem at all i just stating the facts. A lot of tweakers donīt realy know about this. You get more PI distortion and less power tube distortion. And the presence changes by the turn of the master volume. Good or bad, i have no opinion about that.
I rely on preamp design pre PI for all distortion sound when i build stuff. There are ways to get the preamp to sound pretty close to output distortion.
Old 06-21-2008, 11:33 PM   #11
If you have FDB ...
Around here we spell that NFB (Negative Feed Back).
Just, y'know, trying to help.
Don Moose is offline   Reply With Quote
Old 06-22-2008, 09:10 AM   #12
Thanks, iīm from sweden and thatīs my excuse
Old 06-22-2008, 08:27 PM   #13
Supporting Member
Steve Conner's Avatar
I have to agree with that. I don't see what's wrong with the idea of getting distortion from the preamp alone that sounds good at moderate volume. When you need it louder to do a gig, then you can turn the gain down on the preamp and start overdriving the power amp.
I always found that my amps need totally different settings for playing at home as opposed to gigging, anyway.
Steve Conner is offline   Reply With Quote
Old 06-22-2008, 10:28 PM   #14
hasserl's Avatar
ANY master volume, whether pre or post PI, will provide for less power tube distortion. Whether you prefer the distortion to come from the preamp or the phase inverter is subjective and a purely personal preference. If you prefer the distortion from the preamp, that's cool, that's for you. But the thread is about post PI MV's, so I'll going out on a limb to assume the OP has already considered those things.
But if output distortion is what you want, you'll most likely want to put the MV after the PI, because that's where most output distortion comes from.
Old 06-23-2008, 07:30 AM   #15
Well, i understand that. I just wanted to say that its just not that you can feed larger signal into the PI that makes for gretaer distortion but the effect of a NFB plays a part. And the presence changes as well.
But as the threadmaker doesnīt have any NFB it doesnīt apply to him but maybe someone else could use the info. And maybe undertstand more why its sounds the way i does when you have post PIMV and NFB with presence.
5e3 master volume? shoegazed Mods & Tweeks 3 04-11-2008 10:40 PM
Master volume - switchable txstrat Theory & Design 8 03-13-2008 12:36 AM
master volume for 5E3 k51502 Guitar Amps 4 12-06-2007 03:38 PM
5e3 master volume??? playafndr 5 E 3 5 10-24-2007 05:32 PM
Post PI master daz Mods & Tweeks 1 02-10-2007 07:41 PM
