Why did he suggest this? Are you blowing fuses?
They should work fine in your amp. Does your amp use two or four output tubes? I personally never recommend mixing brands or new and old output tubes unless they have been current matched.
You need a multimeter with a diode check setting or at least an ohmmeter. Place the leads of your meter across the diode leads and check the reading. It should either read open or some small value. Now reverse the leads and if the original reading was low, with the leads reversed, the reading should be high. If the original reading was high, with the leads reversed, the reading should be low.
LinkBack URL
About LinkBacks
