| | #1 |
| Supporting Member Join Date: Mar 2007 Location: UK
| PSU -ve rail voltage drops under load
Here is the power supply for the switching and button filament lamps for a very large (and very nice) old studio mix/record desk. It's a DDA, about 40 yrs old I think. The -22v rail runs the filament lamps in the buttons - maybe a hundred of them. But once you switch more than a handful on, the voltage drops away. You can draw very little current from that -ve rail. I have tested both the 22v -ve and the 22v +ve rails on the bench by running them into a low-impedance load. The +ve rail stays up fine, but the -ve voltage drops away the same as it does when running the desk. I have tested all the semiconductors and they are fine, the diodes all give a beep, though I have not tested the zener voltage on the 12v zeners. Any ideas where else I might look for such a fault? Thanks in advance! |
| | #2 |
| Senior Member Join Date: Jun 2006
What does the voltage do before the regulator? If it drops significantly then it is probably a filter cap problem. With a PSU this old I would replace all the electrolytics. If that doesn't fix it then there is likely a problem with the series pass transistors or their controlling components - zeners, associated small transistors, resistors etc. RE |
| | #3 |
Thanks Rick I'll check all that out.
| | #4 |
OK I cured it - thanks again Rick! Under load the correct voltage was there on the transformer side of the 2n3055s, but dropped away the other side. They were biased right, but not conducting. They both gave healthy beeps on the diode tester both on and off the board, but I replaced them both anyway and back came the voltage. First time I've seen power transistors that give the right beeps but don't conduct. To do with the fact that in this application they conduct DC maybe? Last edited by Alex R; 07-08-2008 at 08:46 PM. |
| | #5 |
Oh, they always conduct DC.
| | #6 | |
| Senior Member Join Date: Nov 2007 Location: Owosso, Mi
| Quote:
__________________ The farmer takes a wife, the barber takes a pole.... | |
| | #7 |
[I don't know "A Dorian" from "a Delorean"] Simple - "A Dorian" is just a G Major scale played over the key of A. {A, B, C, D, E, F#, G, A} |
| | #8 |
Would that be a gray scale?
| | #9 |
Actually, it's one of the most common "Blues" scales. I'll be all over it tonight...
| | #10 | |
| Senior Member Join Date: Jul 2006 Location: Baton Rouge,LA
| Quote:
I like the hypodorian other wise known as the Mixolydian. Enzo wrote a song called Muting Fet Blues and I wrote the music and recorded it but never finished it all the way. It was only about five years ago but anyway it was in C Dorian so I guess I should finish it ey?
__________________ KB | |
| | #11 | |
| Senior Member Join Date: Apr 2008 Location: Oceanside, NY
| Quote:
Substitution is a legit form of troubleshooting. | |
| | #12 |
SO you didn't like my Dorian Gray reference? Perhaps if I painted a portrait...
| | #13 |
| Senior Member Join Date: Mar 2008 Location: Cincinnati
| | #14 |
| Vickers scale....its harder for me to explain it then it is for me to just play it...
| | #15 |
[SO you didn't like my Dorian Gray reference?] Sorry - I'm a litle slow sometimes. The police refer to it as "impaired"... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Non-electrolytic replacement caps, Orange Drops, etc - Your thoughts please? | olddawg | Repair and Restoration | 32 | 03-01-2009 02:59 AM |
| Output Tube Load Resistance, Tube Current and Voltage | tubeswell | Theory & Design | 4 | 05-31-2008 05:37 PM |
| PSU question | daz | Theory & Design | 0 | 05-05-2008 03:31 PM |
| EH memory man/drops volume | Jay | Guitar Effects | 1 | 03-02-2007 08:18 PM |
| Rail Pickup Bobbin...ever taken one apart? | psw | Pickup Makers | 13 | 10-30-2006 03:23 PM |
