| | #1 |
| Member Join Date: Sep 2006
| Cathode follower cathode resistor question
Can anyone tell me what different values for the cathode resistor on a cathode follower do? Basically, I'm looking at the tone stack driver for a Marshall, and the cathode resistor there is 100k... The same as the plate resistor on the preceding stage. On a vox top boost or ac-50, it's 56k, but the plate resistor on the preceding stage is still 100k. What difference does this make in the tone? Thanks. |
| | #2 |
| Member Join Date: Jul 2006
there was a long discussion about it at the ax84 forum not too long ago. you should jump over there and do a search. I think you will find what you are looking for. Joe N. |
| | #3 |
| Lifetime Member Join Date: Jun 2006 Location: Connecticut
Mark, In the Marshall direct-coupled CF circuit, the follower's cathode resistor (along with the CF grid voltage) sets the idle current of the CF stage, determines the output voltage swing (it has far more effect on the negative swing than the positive), and - most importantly IMO - sets the point at which the CF stage will draw grid current. If the Marshall circuit's CF is biased hotter with a smaller-value Rk, its grid will conduct earlier, loading down the preceding gain stage and causing it to distort sooner, and in a more symmetrical manner. To my ears, this results in a much better quality of distortion than a conventional gain stage clipping by itself; "all the grind, without the fizz" - whatever that means. Ray |
| | #4 | |
| Quote:
| | #5 | |
Mark, Quote:
Ray | |
| | #6 |
| Junior Member Join Date: Aug 2006 Location: East Grinstead, England
| Source Follower driving tonestack
This mechanism is very interesting. I wonder how it applies to the use of a MOSFET source follower used in the same way. I have used a source follower (RG Keen style) in a SLO100 type amp and never gave a thought to the fact that the GS plate resistor was 220K and the SF source resistor was 100K. As a drop in replacement for the standard CF driving the tone stack it has worked transparently, except for the fact that I mistakingly used a 220K gate stopper resistor instead of a 220R resistor. When I changed it to 220R I came to the conclusion that the sound had been a little smoother with the 220K gate stopper and decided to leave it that way. There does not appear to have been any detrimental effects in spite of the fact that the amp has been gigged hard. I would like an explanation as to the implications as in truth, I dont fully understand what is actually happening. How does the gate in the SF behave compared to the grid of a CF? Any insight welcome, TDS |
| | #7 | |
| Senior Member Join Date: Aug 2006
| Quote:
| | #8 |
| Junior Member Join Date: Sep 2006
| Ray could you explain further? In the direct-coupled CF, both triodes have the same B+ and the same operating voltage. So don't they clip at the same level, regardless of the value of the CF cathode resistor? The cathode resistor mainly affects the average current in the CF. So it would seem the choice of Rk is largely about how much signal you get thru the stack vs how hot you want to run the CF.
| | #9 | ||
woodyc, Quote:
Assuming a 12AX7 GS/CF @ 350V B+, 100K Rp/1K Rk (GS), 100K Rk (CF): The GS will be drawing @ 1.5mA (out of 2.5mA max), and will have @ 200V across the tube. The CF will be drawing @ 2mA, and will have @ 150V across the tube. IMO these are quite different operating conditions, even leaving out the apples/oranges nature of a conventional GS vs. a CF. With these quiescent conditions, at some point during the positive GS swing the CF will start to draw grid current, and the loading on the GS plate will change from very light to much heavier, and the positive swing will take on a rounded character (this is by no means what I'd call 'hard' clipping, but it's quite apparent to both the ear and the 'scope IME). Quote:
Ray | ||
| | #10 |
| hey you're right... sort of
I didn't realize how close to saturation the bias ends up in those CFs. I was just plotting up the construction on p.391 of RHD4 for a 12AX7, and with Rk=100K the available + swing is only about 40V. When Rk goes smaller the bias moves even closer to saturation (as you said.) But the distortion doesn't get more symmetrical, it gets less symmetrical. And I would describe it as pretty hard clipping. I've got a 2204 preamp on my bench and I added a switchable Rk to the CF. I could post a scope trace if anybodys interested. Its a sticky and interesting design problem since with a stack load you want max current in the CF but with the forced bias thats available you actually get more headroom with less current. I guess the way Fender/Marshall wired it up isn't a bad compromise. You could do better by sacrificing a little gain (not a problem in the 2204) and splitting the previous stage plate resistor so you could get more dc volts to the CF grid. But then I guess you'd bump up against the 12AX7 heater-to-cathode rating. I'll stop thinking out loud now. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Resistor voltage ratings | Paul P | Build Your Amp | 9 | 10-12-2009 05:59 PM |
| Grounded Cathode | LastManOnEarth | Theory & Design | 4 | 12-21-2008 06:43 AM |
| 4X6V6 Cathode Bias | stokes | Theory & Design | 27 | 03-08-2007 06:13 PM |
| larger tail resistor mistake? | stevesamps | Theory & Design | 7 | 08-16-2006 02:41 AM |
| Filter cap bleed resistor with 5AR4? | Normster | Theory & Design | 3 | 07-04-2006 02:19 AM |
