Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 07-21-2008, 02:04 PM   #1
PCB design and high voltages
Hi,
I need some help designing a PCB for a tube amp. I would like to know how high voltages relate to traces width and thickness and spacing between them?
Can you point to a standard, application note or calculator for this?
Thanks.
GainFreak is offline   Reply With Quote
Old 07-21-2008, 07:43 PM   #2
Google "high voltage" trace clearance and you can become an expert, which is a good idea if you're doing a board for a tube amp.
BackwardsBoB is offline   Reply With Quote
Old 07-21-2008, 09:56 PM   #3
Lifetime Member
Quote:
Originally Posted by BackwardsBoB View Post
... you can become an expert, which is a good idea if you're doing a board for a tube amp.
Amen, Brother!
Tube amp PCB layout is not for the beginner, unless they have very deep pockets indeed.
R.G. is offline   Reply With Quote
Old 07-21-2008, 10:11 PM   #4
Actually I'm not a beginner - I have several tube amp layouts that work without any problems so far. I just wanted to make sure they comply with the standard.
Old 07-21-2008, 10:16 PM   #5
I didn't mean to blow you off. I have a similar problem. It took me a few tries on Google to get good links, but the search I recommended will point you to standards and calculators.
If you've already done a few boards, you know it's all in the details.
Old 07-21-2008, 11:15 PM   #6
Supporting Member
Steve Conner's Avatar
http://www.ce-mag.com/ce-mag.com/arc...uctSafety.html
enjoy
FWIW, one of my favourite things about tube amps is that they don't require PCBs. I do PCB layout in my day job, in fact I just finished a 6-layer mixed-signal motherboard with 350 SMT parts and am sick of the things.
Steve Conner is offline   Reply With Quote
Old 07-21-2008, 11:33 PM   #7
Lifetime Member
Quote:
I love doing PCB layouts, I find them very therapeutic after a month or more of schematic or software design. I just finished a very dense 10-layer 5/5 one with via-in-pad footprints for a 484-pin BGA and 256-pin BGA. I had to use 0402 bypass caps in between the via pads on the back side of the BGAs for decoupling. The board fab house didn't do a fill and level on the in-pad vias, so the stuffing house was complaining about the reflow, but the boards seem to work so far...
Randall Aiken
raiken is online now   Reply With Quote
Old 07-22-2008, 12:29 AM   #8
Lifetime Member
Quote:
If by that you mean safety standards... good luck!
I just recently fought this battle and mostly won it. But it's an issue of far more than PCBs.
You're going to want IEC600650, that being the one which relates to musical gear among other things (like refrigerators and other appliances... )
A copy of that will set you back between $200 and $400. No, they are not given away free. The standards organizations sell them like novels.
A safety standard does NOT tell you what to do to be safe. It tells you if you don't do at least this much you are definitely not safe. While that may sound like sopistry, it's an important legal distinction. You cannot and will not get the information you need to pass safety certification (e.g. CSA, CE, CCC, etc) on an internet forum.
If you have to meet a standard (in the USA, you do not; you can be sued even if you do: in Canada, you must meet standard; in the EU, you must meet the standard but are not shielded from lawsuits by it; in... in... - it's almost like there's a different law in each country, isn't it?) then you need a quick education. I recommend reading "Practical Guide to the Low Voltage Directive" by Gregg Kervill and "Electrical Product Safety" by Tzimenakis and Holland to start with, buying a copy of the standard, and then hiring a local certification engineer to review if not actually collaborate.
And remember - it's not me, or you, or anyone on this forum you have to convince you did the right thing.
It's the judge and jury.
Old 07-22-2008, 10:54 AM   #9
Supporting Member
Randall, sounds like fun We actually bought a single board computer module in to avoid having to deal with BGAs. I figured that we could always redesign it all on one board if it got popular.
The flipside of RG's argument is that, since standards don't protect you from litigation, there's no point in bothering about them. As long as your product doesn't kill anyone or set fire to anything with insurance, I'd bet nobody would even notice a complete absence of safety approvals
Better still, sell it as a kit, and in court you can argue that it was badly assembled.
Old 07-22-2008, 03:11 PM   #10
Lifetime Member
In the USA, yes, that works. In the EU, since the testing labs are no longer paid by the government, the game works like this: selling equipment without a "CE" mark is forbidden by civil law, with big fines. Putting a fraudulent "CE" mark on equipment that is clearly non-compliant is a criminal offense in most EU countries. if the testing lab receives a "complaint" of non-labeled equipment, they do a formal test. If that test reveals that the equipment is non-compliant, they are authorized to charge the full price for the formal testing to the manufacturer or seller, as well as most likely being the place that gets the business for re-testing after repairs. So the testing labs have become bounty hunters. They can drum up business by just hunting down non-compliance. In the EU, you **will** get noticed if you have no CE mark on new equipment.
The water is murkier for kits. I didn't look into that. I suspect that one had better be in a position to prove that the kit, assembled to the letter of the instructions and including likely mistakes would pass CE muster. It's hard to argue that a PCB with too-small spacings would get better when assembled. In any case, if it's not CE labeled, the person who builds it may not legally sell it to someone else, and perhaps not even give it away. I'm not an EU lawyer, I just read safety standards and associated literature for several months solid. That is NOT enough. +
Old 07-22-2008, 04:17 PM   #11
Quote:
FWIW, one of my favorite things about tube amps is that they don't require PCBs.
Depends on the amp. If you have 3 channels + couple of effects built in + uCU for switching not using a PCB is possible but is a real nightmare.
If this is the case we're all screwed.
Then what about a private person selling a DIY effect/amp on eBay?
Old 07-22-2008, 04:23 PM   #12
Supporting Member
Well, all you really need to do is make sure that your equipment would comply with the CE mark if a lab ever tested it, and keep a low profile. You have to try really hard to make a tube amp fail an EMC test (though if you wanted to, putting a uC in it would be a good place to start!) so it's basically just safety.
There are grey areas: for instance, if I bought someone else's homebrew amp on Ebay, am I right to expect a CE mark? If I got tired of one of my homebrew amps and sold it to a friend, and it malfunctioned and burnt their house down, would their insurance company sue me for the damages because it wasn't CE marked? Could they tell from the remains whether the CE mark was fake? If I left the country, would the loss adjusters come after me? And so on.
I personally don't sell any of my homebrew equipment that plugs into a wall socket, for this and similar reasons. I come across similar dilemmas all the time at work, but since I work for a limited liability company, it's not so much of a worry.
Old 07-22-2008, 04:49 PM   #13
Lifetime Member
Unfortunately, a uC or DSP is necessary if you want to implement MIDI switching or digital reverb/effects...!
Speaking of DSP, has anyone here ever played around with the Freescale Symphony DSP chips? I like the idea that they are using a free Eclipse-based toolset for the IDE...AD and TI charge a small fortune for their development software.
Old 07-22-2008, 04:51 PM   #14
Lifetime Member
Quote:
And just wait until the RoHS non-compliance fines start rolling in....
Old 07-22-2008, 04:56 PM   #15
Lifetime Member
Unfortunately, it looks like everything is going to either BGA or those tiny QFN leadless packages like most switching regulators come in nowadays. It makes hand-assembly nearly impossible, even for prototypes.
Old 07-22-2008, 06:08 PM   #16
The procedures are not exactly as you describe.
Testing labs do what the name says: testing, they're not authorized to chase non-compliant stuff in shops. This is up to Electrical Safety Board to do. They do sample control of whatever crosses EU boarder, currently they have a spy glass on chinese imports. No CE mark means immediate ban. If CE mark is present the importer/distributor or whoever has put the product on the market is asked to present documentation proving compliance in 48hrs. That documentation is called "Technical File" and has to be maintained by manufacturer if he did all compliance certification testing himself or by the accredited test facility that did the testing and issued certificates. The later is the best way to do it.
Now, certification testing by accredited lab is NOT mandatory. Compliance with safety norm is. As manufacturer you are declaring compliance. You are free to declare compliance "by design" but must be able to prove it.
As for tubes amps having no problem with EMC compliance - that is not the case. Have seen quite a few that didn't even though there were no digital clocked circuits in them.
Undersized PT and heavily distorting amp will feed a lot of garbage back into power line. PT will probably overheat anyway leading to non compliance verdict.
Poor grounding scheme will cause the amp to amplify irradiated RF and send it out with mains/input/speaker cable as antenna.
Switching spikes from SS rectifiers if not snubbed are RF sources.
You can build an amp for your own use AT HOME. Officially you're not allowed to use in public venues, lend or sell it unless you put CE mark on it and can prove compliance. But nobody I know cares.
If I receive an amp with 2-prong cord for repair I'm obliged to replace it with earthed 3-prong. If customer refuses I'm obliged to cut the mains cord off. What the customer does after he leaves my shop is not my concern.
I involve an accredited lab from early stages of design. This one is run by senior engineers who are tube geeks themselves, they just love having "something fun and real" to certify as a welcome interruption to all chinese coffee grinders and such.
RoHS is a totally different barrel of bile.
__________________
Aleksander Niemand
Tubewonder amps
Life's a party but you get invited only once
Alex/Tubewonder is offline   Reply With Quote
Old 07-22-2008, 06:45 PM   #17
Lifetime Member
Aye, there's the rub.
1. "... make sure that your equipment would comply..."
The ONLY way to do that is to have a certified lab test it, unless you yourself are an experienced compliance tester. It's a little like saying "all you need to do to successfully remove a brain tumor is know all that surgery stuff so you would be licensed as an MD and pass the necessary exams and so on". Worse yet, some of the issues are ambiguous, and whether you would pass can turn on the interpretation of a single word in a phrase of the standard.
I was proud of the fact that I pointed out some issues in the standard to the reviewers I hired. But they in turn pointed out items that needed changed even though I had been through the standard with the design documents line-by-line-by-line multiple times.
That's why I put "complaints" in quotes. No they are not authorized to go chasing down business. But someone brings issues to the Electrical Safety Board's attention . You can also be waylaid and not be able to keep a low profile if you have any competitors who might not like your products. It's a system that's rife for corruption and spite.
I may have not been clear. Yes, "Safety" is mandatory, as explained in the standards. That is, you are responsible for any damages to people, property, or animals that results from unsafe conditions in your product. However, compliance with safety standards is no longer presumptive safety as it once was.
In the day when European testing was nationally mandated, approval by a compliance lab meant that you WERE by legal definition, safe, and hence not liable. Now, the standard is a de-facto minimum. If you do not at least comply, you could easily be argued as being inattentive to safety minimums. But if someone gets hurt or killed, you are still liable, even if you met the standard. However, if you can prove you met the minimums, you cannot be said to be reckless and irresponsible.
What the current system does is perform responsibility splitting. If you have a certified lab do a report and you put on your CE mark, then you can tell people who bring claims to go argue with the lab. It's a version of the old adage that if there are more than two signatures on the form, the blame can never be placed accurately.
As for tubes amps having no problem with EMC compliance - that is not the case. Have seen quite a few that didn't even though there were no digital clocked circuits in them... Poor grounding scheme will cause the amp to amplify irradiated RF and send it out with mains/input/speaker cable as antenna. Switching spikes from SS rectifiers if not snubbed are RF sources.
I'm glad to see someone aware of this. Most people have no idea.
Old 07-22-2008, 06:47 PM   #18
Lifetime Member
Quote:
That turns out to be a "bookkeeping tax". All you have to do to pass ROHS is to be able to show that all the parts and materials you put into your amps were represented to you as ROHS conforming. That then lets you off the hook in favor of pursuing the much fatter target of a part manufacturer committing fraud.
Old 07-22-2008, 08:35 PM   #19
Supporting Member
Well, we're talking about actual tube amps here, symbols of an era when technology was simple enough that people had a hope of understanding it. I personally draw the line at op-amps, maybe OTAs, in my homebuilt music gear. If I wanted MIDI and digital FX, I'd buy a Line 6, since they already have that down.
I'm looking forward to the Line 6 DSP stompbox DDK coming out though! I think that's the same Freescale Symphony DSP that RG mentioned, though I always think of those as the Motorola 56k series. I've written stuff for the ADI 21xx and TI 67xx DSPs before, and I know a guy who does amazing audio things with the Microchip dsPICs.
All I'm trying to say is that the whole RoHS/CE thing is a nightmare. I'm not debating this. I'm just wondering what it means to a mom and pop shop. I guess they have two options: close up, or go underground and hope they don't come onto anyone's radar. I took the option of working as an EE in industry and leaving amp building as a hobby. It means I end up designing boring industrial electronics instead of groovy boutique amps, but it also means someone else is paying for the compliance testing, and someone else getting sued if it goes wrong, which suits me just fine.
Old 07-22-2008, 08:51 PM   #20
Lifetime Member
And that is the heart of the matter. These weasel bureaucrats, politicians, and environmental do-gooders are killing the spirit of independence and making small businesses nearly impossible to run, either from being inundated with paperwork, or by being forced to pay lots of money for ever-changing regulatory compliance. It is quite sad.
Randall Aiken
Old 07-22-2008, 10:32 PM   #21
It's also called Corporatocracy.
Old 07-23-2008, 03:06 AM   #22
Lifetime Member
Amen.
However, by and large in the USA we get the government we deserve. We have inherited a simple, effective way to get rid of the weasels. That we do not use it is a tragedy. There is a reason HOR terms are two years. What kills me is that the whole congress does not turn over every few years. I find it amazing that people can be unaware of these issues; and never connect up the dots that having a government in your shorts in any way is a Bad Thing.
There is a book that's worth reading. It's called "A Parliament of Whores" by P.J. O'Rourke.
Old 07-23-2008, 10:39 AM   #23
From PCB creepage distances to government in your shorts. Hilarious, you guys are ....creepy
Anyway, there was a case of one company reporting a competitor for RoHS non-compliance. Both got investigated and guess which one was found non-compliant?
Here in Sweden the Electrical Safety Board has it's own inspectors who pick products randomly or act upon a report of a documented electrical mishap. One distinct difference between EU Safety Boards and UL in US is that UL is a profit driven Inc.
Complaining that your cat died when you attempted to dry its fur in a micro does not count for anything other than having yourself declared an idiot and doing time for cruelty to animals.
The only state agency that will investigate on anonymous tip is the Tax Office.
Corruption is a funny thing, definition varies with geography. We don't care about our politicians sex life unless they get involved with minors or porn. Their job is in danger if they use a government issued credit card to buy toys for their kids or do cut and paste tricks with job related expense receipts.
An interesting thing: a product liability insurance policy with EU insurance company states clearly it does not cover USA. For that you need additional policy that costs 5x more. Thanks to great American tradition of suing everybody for anything. What if all these lawyer fees were put to getting stuff properly tested and certified?
BTW. CE mark also implies that the product is accompanied by a user manual including detailed safety instructions. Mine has 5 pages of them. Warranty & product registration card must be signed by customer and returned by registered mail. If the statement: "I have read and understood safety instructions" is not initialed all bets are off.
__________________
Aleksander Niemand
Tubewonder amps
Old 07-23-2008, 12:10 PM   #24
No argument from this American. I don't care about politicians' sex lives either. Unfortunately I am a minority. Over here if we can point a finger and find someone to blame for something, we consider the job done. We don't really try to change anything, we jist want that AHA! moment, and then we forget it.
It is a fine old American tradition swapping stories about who sued whom for how silly a thing. "Did you hear about the guy who...?" I am sure they are really the exception, but we hear about incidents like the fellow who dropped a car battery on his foot as he was trying to install it himself, and successfully sued the battery manufacturer.
In some parts of the world, if you bring suit and lose, then YOU are responsible for the other party's legal expenses. I like that plan, that would stop a lot of frivolous suits.
Old 07-23-2008, 01:23 PM   #25
Supporting Member
Anyone know how to calculate creepage and clearance for one of these?
http://www.neighborhoodvalues.com/nv.../misc/35kc.htm (notice that it was in an online store: someone sold it)
Alex: The Scandinavians are so sensible, they could make even the most messed-up political system work fine. I've never visited Sweden, but I've been to Norway and Denmark on business and loved it there. I'd consider emigrating if it weren't for the price of beer
Old 07-23-2008, 04:44 PM   #26
Lifetime Member
Yeah, but you folks in Sweden are **sane**. Not so in the USA.
Old 07-23-2008, 04:47 PM   #27
Lifetime Member
Actually, it's possible for that one that passing creepage/clearance was a breeze. An interlock switch on the cover would be all that was needed.
Of course there are other sections of the standards that might not let that one pass today.
Old 07-23-2008, 06:00 PM   #28
We do have our share of people endowed with "alternative intelligence" in every walk of life. It's not all nice and cosy over here even though it may look this way from across the pond.
__________________
Aleksander Niemand
Tubewonder amps
Old 07-24-2008, 07:58 PM   #29
Quote:
I dont care, and there is some of my crapy jobs out there on the swedish roads I will do like Clinton does, deny, deny, deny. I did not have solder intercourse with that amp
Tubis is offline   Reply With Quote
Old 07-26-2008, 10:07 PM   #30
Hi guys.. I'm an absolute newcomer to this forum....
55 yrs EE in instrumentation and telemetry.. lifelong "audiophool" and snake oil sceptic.
Dumped in here because of a guitar freak son.. ( otherwise he's a good lad...)
[QUOTE=Alex/Tubewonder;67572]
[/QUOTE
Even if this and other stories like this may be "designed", I've often wondered how the US legal system came into this "I'll sue you and you'll sue me" situation... I recently read a report that this legal lunacy is costing the US society something like 5.000.000.000.000 $, all together.......? Hm.......
But, to the case..
The CE and UL stuff is of course applicable to all aspects of "homegrown" electronics, not only musical related. I started loking into this some years ago, but dropped out along the way. Most of my passtime audio work has been with loudspeakers, although I've made my fair share of amps, but I've never sold anything to other than fairly close friends. Now this questions is again relevant, 'cause of my sons interest in guitars, as there's the chance that whatever I may build may be traded for something else, in the eternal quest for "the holy grail of tone.."
Alex.. do you happen to have any links to relevant documents regarding CE and safety...?
For the rest of you - the old pre CE swedish and Norwegian regulations very mostly identical, and for most a certificate from the old swedish SEMKO ( official swedish testlab) was automatically accepted by the norwegian NEMKO, and vice versa....Norway and Sweden were known to have some of the strictest regulations for electrical safety in the world...
Halgeir Wold
Norway
Aurora is offline   Reply With Quote
Old 09-03-2008, 10:15 AM   #31
Or do repairs....
booj is offline   Reply With Quote
Old 09-13-2008, 10:32 AM   #32
PCB Madness and Litigation
First:
Back in the 60's and before,people innovated without a "Big Brother" fear.There was a very common AM radio circuit called the "All American 5"...
5 tubes,filaments wired in series,no power supply transformer.The radio's had every knob,screw,etc. insulated or made out of insulated material. I'm positive some folks died as the result of stupidity (washing the radio when it was on)...but for the most part,they were good products,and inexpensive.That's why some tubes had 50 volt filaments (50L6 comes to mind)....
I think MOST companies went to task to make products as good and dependable as they could, balanced with safety concerns.There were, however, professional service technicians who fried their test equipment working on those "Hot Chassis" products.I remember the isolation transformers coming onto the market....
Secondly:
PCB's and tube amps don't mix well. I've had Guitar amps that had to be "RE-Wired" with real wire, not traces, because the heat,mechanical strain,and voltages were a bit much for circuit boards.
Look at the classic Tube amps...Fenders,Marshalls, Vox,among many.
Now look at "Modern" Tube amps with PCB's....chinese - built junk.
Not worth much money,even when new. Who wants them? Maybe as the basis of a "Modded" amp....putting in all the non-pcb stuff,to make them more reliable.
New circuits:I'm working on my brother's Line 6 floorboard....no luck getting out of the manufacturer what the parts in ANYTHING are.In fact - They actually told him "We don't make the products; we design them".
So:Unless you are a "Factory authorized service center", you can't find out what the IC's are (house marked).There will be precious little modding of their products! Do you think that equipment will increase in value over time?
And unless you have a few Million $ to spend on design and marketing,you won't come close to any of the Emulator's.
The "Throw away society". People actually bought products in the past that were meant to be fixed.
Vintage amps and modern high - value amps use point - to -point wiring,period. They will always hold their value.
>>>> End of Rant <<<<
guitronics is offline   Reply With Quote
Old 09-13-2008, 05:19 PM   #33
Supporting Member
loudthud's Avatar
I designed PCB's back in the days before PC computer drafting. Bishop Graphics published a book that had design rules for clearance vs voltage and line width vs current. (Naturally, copper thickness and plating was taken into account.) The line width specs told you what the trace could take but often the voltage drop was more than you would like. To get the voltage drop you had to go to a physics book and calculate the resistance of the copper trace to control voltage drop. UL also had specs that called for additional clearance around traces that connected to the incoming power line and clearance to ground. There was also a UL spec having to do with line width next to the edge of a PCB because there was a tendency for those to start a fire. I'll see if I can find some of those specs.
loudthud is offline   Reply With Quote
Old 09-13-2008, 10:35 PM   #34
Unfortunately with amps becoming more and more complex you can't get away without PCBs unless you want to enter a real nightmare.
I recently ordered out of curiousity some RoHS compliant PCBs from the local PCB shop and tried some RoHS solder along. To tell you the truth it's a BIG pain in the ass to solder these. The solder melts at higher temperature and it takes longer for it to spread over the pads.
Below is an online calculator I found concerning traces, current, resistance etc.:
http://circuitcalculator.com/wordpre...th-calculator/
Old 09-14-2008, 09:21 AM   #35
PCB's
Wow,Loudthud...
What a headache! I imagine PCB design is still a pain...inductance between traces,timing circuits going haywire because of stray capacitance,etc.
I know Large scale Integration and PCB's are the only economical way for Manufacturers to recoup their investment, in almost all Consumer Electronics.
The very idea of "Mega-Scaling" is a necessary evil.
I'm just glad for the things that aren't "Proprietary" and can be hacked and modified.
Like Guitar amps that are point-to point.
voltages too high cminor9 5 E 3 1 04-18-2008 02:07 AM
high plate voltages in blues deville slapbackdaddy Maintenance, Troubleshooting & Repair 22 09-15-2007 06:43 AM
Hi Fi to Champ conversion questions: Voltages too high? Regis Conversions 11 04-18-2007 03:20 AM
High voltages afer recap!? Richard Maintenance, Troubleshooting & Repair 14 03-20-2007 06:03 PM
Measuring voltages in a very high impedance circuit JC@ Theory & Design 4 07-04-2006 02:48 AM
