Go Back   Music Electronics Forum > Effectification > Guitar Effects
Old 07-23-2008, 09:22 PM   #1
Mojo Vibe
Working on broken Mojo Vibe. The wrong power supply was plugged into this pedal and now it does not work. I believe there are some protection diodes in there and they are 1N5817 schottky diodes. These diodes are rated at forward voltage drop of .45-.75 depending on current. Could I replace these w/ a 1N400x type? I'm thinking this will work but what might the 1N400x type not do that the 1N5817 would do better?
lowell is offline   Reply With Quote
Old 07-23-2008, 10:04 PM   #2
anyone have a schem for this pedal? There is signal but no effect.
Old 07-23-2008, 10:30 PM   #3
If no schem... anyone able to explain how the voltage converter op-amp works? (MAX1044 ). Or if these pin voltages seem good or bad?
All are DC volts:
1 9.56
2 7.29
3 0
4 .28
5 9.56
6 6.8-7.26
7 7.2
8 .28
Old 07-24-2008, 01:57 PM   #4
Supporting Member
I fixed one a while back. The problem was the MAX1044 was not driving the lamp. The Max1044 is configured as a voltage doubler, so the lamp voltage should be 15v or higher. I never could find a schematic.
The 1N5817 schottky diodes turn on faster than the 1N400X series. I believe the purpose for using these is two fold. One, to protect against a reverse polarity power voltage and two, to suppress transient voltage spikes. They kill two birds with one stone where the 1N400X just protect against a reverse power source.
CJL
cjlectronics is offline   Reply With Quote
Old 07-24-2008, 06:04 PM   #5
thanks for you help!
Old 07-13-2009, 08:47 PM   #6
Moo Vibe
I seem to have the same problem with my Mojo Vibe. It seems to work fine most of the time, but sometimes gives off a squeaking noise ( varies with effect rate ). High rates also causes the lamp to get "stuck" at full effect, resulting in no modulation. Iīve found various models of the max1044 - do you know the exact part number of the component used?
I bought the Mojo second hand - I love it, but because I donīt live in the US, it would probably be cumbersome and expensive to send the effect back for repair.
Thanks!
blubp is offline   Reply With Quote
Old 07-14-2009, 01:34 PM   #7
Supporting Member
MAX1044CPA, the 8 pin DIP I think. Its been a while??
CJ
Old 07-16-2009, 12:13 PM   #8
Thanks! That saved my day
Old 09-03-2009, 06:59 PM   #9
Max1044cpa
Just wanted you to know that i ordered a replacement for the MAX1044CPA, fitted it, and sure enough - it took care of the problem. Mine was only partially broken - it would't drive the lamp at high rates.
Mojo Vitamin T's Correct Orientation dpierce05 Guitar Amps 2 05-27-2008 06:43 AM
dunlop Uni-vibe blueskat Guitar Effects 2 05-23-2008 09:41 PM
The ghost of the EZ-VIBE... Don van Strat Guitar Effects 2 04-03-2008 06:30 PM
Mojo Oil Filled Caps Stone Theory & Design 3 04-30-2007 03:47 PM
VL Micro-Vibe schematic jaysg Guitar Effects 0 06-08-2006 11:59 PM
