| | #1 |
| Junior Member Join Date: Oct 2006
| Peavey Ultra Plus doesn't power up
I've recently had an issue with the sound of my Ultra head. The clean channel became distorted. and I lost a lot of power on my distortion channels. I thought it would be best to change out the tubes as the starting point to troubleshooting the problem. I changed out both the preamp tubes and the power tubes to matched GT's and now the head does not even power up. Is there a fuse or something like that that I may have blown or is it likely that I've created another issue? I'm not the most technical person when it comes to amps. Any help would be appreciated. - Thanks.
| | #2 |
| Senior Member Join Date: Jul 2006 Location: Baton Rouge,LA
There are fuses inside the amp and it's most likely the culprit. I would think the caps are discharged by now but I have to warn you there are lethal voltages that can be stored so take caution. One of the new tubes may be bad so you might try them one at a time to see if the fuse blows again. When you get all of the tubes to light and still have problems with volume try patching a guitar cable from send to return and see if you get it back. The front panel lights will only work with the footswitch and it is also possible a faulty pot could cause the volume loss.
__________________ KB |
| | #3 |
| How do I get to the fuse?
OK, so I am hopng the current problem is just a blown fuse. Is there anyway to get to the fuse without taking the whole thing apart? I don't see an easy access to the fuse (you would think there would be). Anyone know where the fuse is located on the older peaveys?
| | #4 |
Same place they are on newer Peaveys - inside the chassis.
| | #5 |
| That's what I thought...
Thanks for the help.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Peavey 400BH | amplover | Maintenance, Troubleshooting & Repair | 4 | 08-18-2009 01:26 AM |
| schematic for Peavey Ultra 112/212 | maniago | Maintenance, Troubleshooting & Repair | 4 | 09-07-2006 01:42 AM |
| Peavey ULTRA PLUS crunch sw problem | Amptek | Maintenance, Troubleshooting & Repair | 7 | 08-23-2006 06:28 PM |
| Peavey Ultra switching problem question | wrkbnch | Maintenance, Troubleshooting & Repair | 5 | 07-07-2006 04:47 PM |
| V-4B Ultra Lo switch | Dave M | Maintenance, Troubleshooting & Repair | 5 | 06-07-2006 01:12 AM |
