Results 1 to 2 of 2
Thread: Mirage powered mixer
    Aug 2008
    1
    Hi All
    Does any one know of a Mirage PM 610 D powered mixer ?
    It is a 6 channel mixer( probably 1980's). Korean made.
    How much power at 8 ohms ??
    thanks marx
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,069
    Google it, otherwise I am no help.
    If you only just want to know its output, measure the power rails for the power amp supply. The peak output will be a little less than those voltages (the positive and negative should be about the same, so measure one of them). Your output to the speaker will have a similar peak voltage. RMS is .707 times peak, and with 8 ohms and the RMS voltage, you can approximate the power output.
  1. yamaha emx 660 powered mixer help
    By dtobian in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-25-2010, 01:50 AM
  2. Johnson JT50 Mirage Amplifier HELP!!
    By roth135 in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-17-2007, 04:24 PM
  3. Yamaha Powered Mixer Emx 860st
    By e_c_mccollum in forum Music Electronics
    Last Post: 04-18-2007, 11:02 AM
  4. Noise when standby on or powered off
    By Thorny in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-15-2006, 05:52 AM
  5. FX into Mixer
    By dumbassbob in forum Music Electronics
    Last Post: 10-29-2006, 04:17 AM
Tags for this Thread
