| | #1 |
| Old Timer Join Date: May 2007 Location: pacific north west
| Power Scaling...again
Sorry I'm all over the board right now. I just seem to have alot of Qs lately. I don't understand how power scaling reduces output (I just know it does?!?) To do it right you should track the bias to mate up with the reduced plate voltage, sooo... How does running, say, an EL34's at 500 volts and 38ma current make more power than running the same tube at 250 volts and 76ma current? They're both 19 watts. Plus thers a max current on that tube of 150ma. So what happens below 130 volts or so when you must exceed the max current rating to bias the tube? Power scaling claims "down to 1/100th" power. I just want to understand this. Thanks Chuck |
| | #2 |
| Senior Member Join Date: May 2008 Location: Los Gatos, CA
If you cut the B+ voltage in half, you need to cut the bias current in half too. This will give you 1/4 the output power, and sound more than half as loud. The ratio of bias voltage to B+ voltage is maintained, somewhere less than -1/10 for an EL34. I guess that this is only an approximation of the ideal ratio function, but it seems to work, and it's fairly easy to implement.
| | #3 |
| Senior Member Join Date: May 2007 Location: Silicon Valley ; USA
Well, then my brake works a little bit differently. Lets say the plate voltage to cathode voltage remains at 500 volts, but plate current is reduced to 10 mills. So, what's that, a plate dissipation of about 5 watts ? -g
__________________ ______________________________________ Gary Moore Moore Amplifiication mooreamps@hotmail.com |
| | #4 | |
| Quote:
Chuck | |
| | #5 |
You won't get really nasty crossover distortion in class AB until your bias current gets near zero. You're normally counting on a bit of negative feedback to compensate for the tubes' inability to source current and correct for the switch from both tubes in the pair conducting at low output voltage to just one pulling anyway. The substantial bias current recommended for normal operation has at least three benefits: 1. The range in which the amp operates class A increases. 2. You insure that when only one tube is pulling, that tube is far from cutoff and at full gain. 3. It's easier to drive the tube to saturation (rock on!). Since you need a master volume or elaborate circuitry to reduce the drive into the scaled circuit when you scale anyway, all three effects pretty much scale too. The output voltage range over which both tubes are sinking current will get smaller, but it will scale with the output voltage of the circuit. For that rare Class A push-pull circuit or a single-ended circuit, the tubes can drive well swinging from near zero current to twice the bias current. Halving the output swing with power scaling halves the bias current requirement. For Mr. Moore, who appears to be scaling screen voltage but not plate voltage, the tube power dissipation will halve. If you scale the plates too, tube plate dissipation is half (V) of a half (I), or 1/4. I feel uncomfortable going into too much detail on this. There's little value in me misrepresenting O'Connor's work, and that's what I'm basing everything on. TUT4 from London Power goes into detail on power scaling, among other things, and they are taking orders for TUT6, which provides discussion of additional scaling circuit solutions. |
| | #6 | |
| Quote:
It's obvious to me that the general macro understanding of power tube operation, while functional for homebrewers, isn't the whole picture. If I work from only that approach : low voltage on power tubes + low idle current+ reduced drive voltage = Woosy a$$ thin sounding power amp with scratchy distortion character. But I've heard the power scaling demos. And while they all seem to be done by outstanding players (which is suspect) they sound good. I guess I still don't get it. If you run the power tubes at low voltage and reduced current. Then you trim the drive voltage to avoid exceeding the low level of bias, are the output tubes really overdriving at all. Or is this circuit just producing the same effect as a post PI master but with a much more complex circuit. Like I said, there's plenty I don't understand. But on the macro view it doesn't make sense at all. Chuck | |
| | #7 | ||
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
| Quote:
Quote:
I have no qualms about misrepresenting Ko'C's work, since I've never seen it and don't ever intend to...
__________________ "Ohhhh miracle bulb shines feebly" | ||
| | #8 |
Supposedly, it's about the "cranked tones" at lower volumes. Yes, can be done with an external attenuator. The thing with electronic power scaling, it's less current stress on the power tubes, and less current stress on the output transformer. When you get that "cranked tone" is when the PA tubes break-over into saturation. At this point, the dc component of the waveform starts to collapse the electromagnetic field in the primary coil of the output transformer, and you get a momentary dc current spike through the power tubes. If there is no external attenuator, the same thing happens in the voice coil of the loud speaker. . Perhaps it's been said it's possible to burn up a 30 watt speaker with a 5 watt amp. Well, this is how it's done. -g
__________________ ______________________________________ Gary Moore Moore Amplifiication mooreamps@hotmail.com Last edited by mooreamps; 08-12-2008 at 01:04 PM. Reason: grammer |
| | #9 |
| Senior Member Join Date: Jun 2008
When I think of power scaling, I think in terms of power reduction. In my variable power 2204 clone, I might say, reduce the plate (and screen) voltage from 400 volts to 200 volts. That means I have to INCREASE the current going through the tube to maintain the same idle dissipation. In my case, I use cathode biasing, which means I have to DECREASE the cathode resistor, to put the grid closer to ground, so the tube will concuct more.
| | #10 |
| Why increase the current to maintain the same idle dissipation? You could let the dissipation reduce along with the plate and screen voltage or better still adjust it to maintain the best tone as the power is reduced.
| | #11 | |
| Quote:
Dave H | |
| | #12 | |
| Quote:
-g | |
| | #13 | ||
| Quote:
Quote:
Look, there's obviously something I'm not getting. But I give. I'm being told that it works by enough people. Well, R.G. Keen said "it seems to work" in the context that people are using it. I'll guess he hasn't looked it over that closely then, or his response might have had conviction. Like "it does work" or "it works". I'll just have to give it a try and see for myself. And I may not have but for your persistance. So thank you for that. Chuck | ||
| | #14 | |
| Quote:
Chuck, I've never made or played through a power scaled amp so you can ignore anything I've said about it. I was only trying to figure out how it could work as well as everybody says it does. I've just done a few simulations and from looking at the waveforms I can't understand how it can sound as good as it's supposed to down to 1/10 power. I was hoping to be able to make the 1/10 power waveform look like a miniature version of the full power waveform but I can't. I was using a continuous sinewave and that's not a guitar signal so it probably sounds better than it looks. Dave H | |
| | #15 |
Why do you "need" to maintain the same idle plate dissipation? I believe one does not. The power tube will still work just fine. -g But it puts out less power. The idea actually is to maximize the idle current for the applied plate voltage supply. Sweet saturated momma tones. |
| | #16 | |
| Quote:
Let us assume one is the form of the variable plate voltage regulator, which would cause us to ask the question, what is the tone for a low voltage operated pentode ? Well, you may hear different opinions on that one. Then, let us assume the other is the circuit that I use, which leaves the plate voltage at a constantly high level, and only varies the plate current that flows through the tube. I prefer this method because I believe pentodes only sound good with high plate volts. I've ready heard hear a few "choice" opinions on that one. But the guys who play though my amps here in the bay area seem to like getting those cranked sounding tones between, I'm guessing between 3 to 4 watts when playing on stage. -g | |
| | #17 |
I had my amp set up for both variable screen, or variable plate/screen supplies. I ran into problems with crossover distortion when I adjusted just the screen supply. That was with 2 JJ 6V6-S's and an Eico 18 watt output tranny. I never went below 7 watts in screen mode. I've switched to a Marshall 50 watt o.t. and 6550 outputs, and am finding that if they are cathode biased just a little cold with full plate/screen voltage, I will get some crossover distortion, but if I move the impedance switch to 1/2 of what I'm using (i.e. 8 ohm load, 4 ohm tap), I get good, fat waveforms with no problems with crossover distortion. Sometimes I hear the wheels of the universe... grinding.... |
| | #18 | |
| Quote:
-g
__________________ ______________________________________ Gary Moore Moore Amplifiication mooreamps@hotmail.com Last edited by mooreamps; 09-08-2008 at 02:43 PM. Reason: content | |
| | #19 |
The screens were about 50 volts below the plate voltage to start. (plates at 450, screens at 400) Then I decreased the screen voltage from there. I got usable results, but there was earlier crossover distortion when the output was pushed into clipping. That phenomena got worse when I switched transformers. So I removed the screen control feature and just use plate/screen control. I'm sure it has a lot to do with the OT vs output tubes vs plate voltage. (OF Course!) That's just my experience. |
| | #20 |
| Member Join Date: Jul 2008
I just completed a MOD that I like better than any power scaling scheme that I have ever tried. It's only five maybe six parts at the most. I read all about it over here. http://www.el34world.com/Forum/index.php?topic=4401.0 This last week I installed this power mod on 5 different amps with absolutely amazing results every time. Do your self a favor and hook it up with the pot and just Dial in your reduced setting. The whole block will thank you for this mod. It's also been a hot topic over at 18wattdotcom Topic: new lite with 1/4 power switch http://18watt.com/modules.php?name=F...wtopic&t=20058 |
| | #21 | |
| Quote:
-g
__________________ ______________________________________ Gary Moore Moore Amplifiication mooreamps@hotmail.com | |
| | #22 | |
| Quote:
| | #23 |
It's a cathode biased circuit, set up so at max. power for that (screen-adjust) set-up it doesn't cook the tubes and still operates acceptably at min. power. I see now that to make it work properly the screen and grid-cathode voltage would have to be adjusted simultaneously.
| | #24 | |
| Quote:
question. What value of series grid stopper you running on your power tubes ?? -g
| | #25 |
From the plate supply through 2k to 50uf. That's the screen supply. Then through 2 1k's to the screens.
| | #26 | |
| Quote:
You don't understand. Not the screen grid. The "control" grid. -g
| | #27 |
Oops! Sorry. 5.6k, and not mounted at the socket. Mounted on the "experimental circuit board". I realize now that at the socket may work better.
| | #28 |
| | #29 |
My first guess would be the output transformer possibly not matching the tubes. An Eico 18 watt output seemed tolike 6V6's and 6L6's, and crossover with EL34's and 6550's. With the CE Dist. Marshall OT, 6550's don't work unjless the impedance is set to say, 4 ohms for an 8 iohm load. And now the subject just diverges. Experimenting in the real world has it's advantages, untill the head just automatically starts diving for the table. |
| | #30 | |
| Quote:
-g
| | #31 |
| Junior Member Join Date: Oct 2008
Hi all, I installed a very simple mod involving 2 Mosfets to reduce the volume out put with my JTM45. It works brilliantly. I can dime it and yet reduce the volume without losing any tone... Just oodles of creamy overdrive. Really cheap at under $30 for complete Fixed bias version. A snip to do. I will just dig out the site address........... |
| | #32 |
Here we go::: Tube Amplifier Attenuator Volume attenautor for both Cathode and Fixed bias Amplifiers. As I said it worked great for me. Hope thats of help. |
| | #33 |
| Senior Member Join Date: Jun 2007
awesome thread.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Power Scaling is Flawed? | tbryanh | Theory & Design | 157 | 02-13-2010 07:09 PM |
| Scaling Bridged-T tone circuit | Steve A. | Guitar Amps | 4 | 07-15-2008 05:57 AM |
| MARK IV EQ Scaling | GainFreak | Theory & Design | 2 | 04-05-2008 05:39 PM |
| Stepped Power Scaling? | tbryanh | Theory & Design | 8 | 10-06-2007 07:23 AM |
| Power scaling | Ptron | Theory & Design | 2 | 08-21-2006 02:37 PM |
