Old 08-18-2008, 04:24 AM   #1
Question Sovtek Mig 50
My Sovtek Mig 50 makes a humming noise for 1-2 sec., then blows a fuse when stnby is switched off. What gives? All tubes light up when in stnby mode.
k00chman is offline   Reply With Quote
Old 08-18-2008, 11:39 AM   #2
Something is pulling too much current. Main suspects are power tubes, filter caps, rectifier diodes, power transformer (in this order).
First thing would be to try new power tubes, if the fuse blows again, take her to a tech.
Cheers,
Albert
Albert Kreuzer is offline   Reply With Quote
Old 08-19-2008, 07:33 AM   #3
Question Sovtek mig 50 blows fuse when stnby is switched off; what gives?
Thanx Albert, i did the old chop stick touch trick and eliminated the short. The tubes stay lit now when in opp mode, but no signal to the spkr cab. I'll take it to my tube tech and take no chances. I'm still in the larn'in stage, and the amp is a midget 50H model, with master contl, not a mig 50 as i posted. Oooops.... !! Any mod's for harp aside from tubes? 30+yrs harp / 20+yrs blues. I'v had 10 or more different amps and got this back waaay cheaper than i sold it, and would like to try it for larger venues. Thanks again; Koochman
Old 08-19-2008, 03:41 PM   #4
+1 on the rectifier diodes. They often go bad in these. I have a mig 50 head played HARD for over 10 years everything is stock (except for pwr tubes) I keep waiting for something to break so I can have an excuse to change the cheesy pots and switches but it keeps on tickin'
If your 50H is anything like my 50 it'll be one LOUD ASS harp amp. Let us know how you make out
Chris
distorto is offline   Reply With Quote
Old 08-19-2008, 09:36 PM   #5
A friend of mine plays harp with a 74 Super Reverb (talk about loud ass). I modded the obsolete ground switch to NFB On/Off and he loves it.
Easy mod: You can try to find the wire from the 8 Ohm tap on your 50H that goes to the 56k (I think) resistor and disconnect it. Add a switch or leave it that way if you like it.
Cheers,
Albert
Sovtek mig 50 issues ? Poffa Maintenance, Troubleshooting & Repair 3 10-13-2008 02:57 PM
Sovtek MIG 60 wui223 Maintenance, Troubleshooting & Repair 26 08-31-2008 09:07 AM
Sovtek MIG 50 help please lowbrow Maintenance, Troubleshooting & Repair 5 04-25-2008 05:20 PM
Sovtek MIG-50 help insanezp Maintenance, Troubleshooting & Repair 6 02-25-2008 09:33 PM
Sovtek Mig-60 No Output jaysengsr Maintenance, Troubleshooting & Repair 6 10-24-2007 01:49 AM
