Results 1 to 3 of 3
Thread: Difference between ECC83 (12AX7) and ECC82 (12AU7)
    Feb 2008
    Stockholm, Sweden
    7
    I'd like to know what the difference between those tubes are and if I can use the ECC82 instead, in an amp that I have an ECC83.
    Jun 2006
    3,315
    12AU7 will probably work fine in the phase inverter position (right before the power tubes),or reverb driver.... In most vintage amps with good quality plate resistors it will be OK in the other preamp stages, ...I would be a little careful with some modern PCB/budget amps with this though, 12AU7 draws significantly more current than a 12AX7 and migh possibly burn up a plate resistor. Plate resistors are easily replaced in the worst case scenario (harp players do these kind subs often and rarely have problems).
    The biggest factor wil be the lower gain of the 12AU7, the impact of this will vary greatly from one amp circuit to another.
    Supporting Member
    Jun 2008
    Italy
    1,139
    Hi,
    though a drop in replacement is theoretically possible, I would not recommend it, 12AU7s have an anode resistance which is one tenth ( and anode current' s ten times as much ), they can accept larger signal swings at the input but their mu factor is one fifth...so I don' t think a drop-in replacement would yield good results, and, as MWJB wisely pointed out, it could rise some reliability issues about power dissipation on plate resistors.
    If I was to replace 12AX7s with a different tube ( e.g. in the case a direct replacement is not available ) I would go for 5751s ( similar ratings and a mu around 70 ) 7025s ( mil-spec version of the 12AX7 ) E83CCs ( Special quality version of the 12AX7/ECC83 ) and ECC803s ( ECC83 with a specially designed spiral heater for low hum ).
    Best regards
    Bob
There are currently 2 users browsing this thread. (0 members and 2 guests)
  1. ecc83 nos test in TV7 tube tester
    By Andrei_T in forum Guitar Amps
    Last Post: 04-10-2016, 11:29 AM
  2. Can I use a 12AU7 based preamp with my SS power amp?
    By armstrom in forum Theory & Design
    Last Post: 08-04-2011, 04:49 PM
  3. Replacing V3 with 12AU7 to cut volume in PV C30/DB?
    By Steve A. in forum Guitar Amps
    Last Post: 08-19-2008, 01:17 PM
  4. Flutter with 12au7 tubes...
    By PlayItAll in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-07-2007, 07:07 AM
  5. ECC83 vs ECC84
    By newfish in forum Tubes (Valves)
    Last Post: 11-18-2006, 06:18 PM
