Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 10-10-2006, 07:29 PM   #1
Mounting Alpha pots - stupid question
Sorry if this been asked before... Couldn't find anything...
I'm finally putting together my first build. My really newbie question regards
the little notch on the Alpha pots. Should I take it off? Does it have a function?
The pot come in all crook when I tight it (obviously ).
Thanks!
__________________
fabiomayo
fabiomayo is offline   Reply With Quote
Old 10-10-2006, 08:21 PM   #2
I've always snipped 'em off, and use a deepwell socket to tighten the nuts while I hole on to the pots so they don't move around.
jonnycat is offline   Reply With Quote
Old 10-11-2006, 03:04 AM   #3
The little bump beside the shaft bushing? It is a locator. Look on some equipment and on the panel you will see a small hole next to the hole for the shaft. The little bump sits in the hole to keep the pot from rotating. For panels without the extra little hole, snip the locator pin off.
Enzo is online now   Reply With Quote
Old 10-11-2006, 04:14 AM   #4
Thanks for that explanation. I already snipped it off. Now's time to bed but
I'm hoping to get the amp running tomorrow. I'll report back!
Thanks guys!
__________________
fabiomayo
Really stupid pickup question - Todd Hepler Pickup Makers 7 11-26-2009 08:27 AM
Bias pots BobD Theory & Design 7 06-25-2007 12:51 AM
proper installation of pots/jacks/switches john t Tweed Builders 10 04-07-2007 02:00 PM
Independent Concentric Pots??? Corona Blue Mods & Tweeks 11 11-16-2006 08:11 PM
quality stereo pots for guitars? Chris / CMW amps Guitar Tech 9 10-01-2006 05:47 PM
