| | #1 |
| Junior Member Join Date: Oct 2006 Location: Hell, Arizona
| Marshall JTM 30 Bias Adjustment
I have a JTM 30 on the bench and there is no adjustable bias. The resistor, R132, which I assume is the one I need to change is burried. Any experience on this model? Any help would be greatly appreciated. kramps |
| | #2 |
| Senior Member Join Date: Sep 2006 Location: Boscawen, NH
I would replace the power tubes on this one (if that's what you're doing) and check bias first before you change anything. It may be fine where it is. If it needs to be tweeked, it may be advantageous to stick a 250k pot (linear) in the place of that 100k resistor if there's room and make it an adjustable bias...it's been a while since I've had one of those on my bench. I just got done fixing a JTM60 but that has a pot in the bias circuit already.
| | #3 |
| Senior Member Join Date: Jul 2006
| Check Zeners 2 x 15v + 9.1v
Hi Have seen a couple here one had burnt power transformer other o/c output transformer. I think for memory I upped the 9.1 zener in both to 11v as it appeared to be pushing the tubes too hard. Schematic here:- http://www.drtube.com/marshall.htm#JTM30. The trannies were hard to get hold of so I would err on the side of caution. Just thought I'd add my tuppence worth.... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Marshall TSL 1000 high bias voltage - help | sonic_tooth | Maintenance, Troubleshooting & Repair | 7 | 10-13-2006 05:48 PM |
| Marshall jcm2000 dsl 100 Bias low | pbdog | Maintenance, Troubleshooting & Repair | 15 | 09-28-2006 01:36 AM |
| help with bias ? | john t | Tweed Builders | 15 | 09-07-2006 11:58 PM |
| Bias measurement | Paul P | Maintenance, Troubleshooting & Repair | 9 | 06-10-2006 01:11 AM |
| 5f4 bias | scole | Tweed Builders | 0 | 06-02-2006 07:23 PM |
