| | #1 |
| Senior Member Join Date: Jul 2008
| What's this cap for?
Any idea what C13 is for in the attached? I don't understand its purpose. I somehow missed it when I ordered parts. Will a .1 uF do instead? |
| | #2 |
| Senior Member Join Date: May 2006 Location: Manassas, VA
thats the so-called "death-cap". Leave it off and instead install a grounded power-cord. Do a search for death-cap....there's bound to be some entries about it. |
| | #3 |
I thought this seemed fishy. Thanks.
| | #4 |
| Junior Member Join Date: Sep 2008
It's there to set the chassis at AC neutral (ground, more or less). Trouble is, unless you have a polarized line cord installed, it can also make the chassis common to the AC hot. DON'T use any larger value than stock, DO install (at a minimum) a polarized cord to force this connection to AC neutral. A better solution would be to install a 3-prong cord and tie the chassis to the ground wire - and remove the cap entirely. -L |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Cap wiring help please. | 347sixtyseven | Maintenance, Troubleshooting & Repair | 4 | 07-13-2008 08:33 PM |
| need help - Old cap can ID | atmars | Maintenance, Troubleshooting & Repair | 3 | 07-07-2008 04:07 AM |
| Cap Job | RiccardoSG | Maintenance, Troubleshooting & Repair | 1 | 06-22-2008 04:42 PM |
| small-value poly cap in parallel with PS filter cap | pvsage | Guitar Amps | 3 | 08-28-2007 04:47 PM |
| cap can caps | scole | Theory & Design | 3 | 11-03-2006 12:27 AM |
