| Music Electronics General discussion about music electronics |
| | #1 |
| Junior Member Join Date: Sep 2008
| Hammond Organ Reverb into Stand Alone Reverb Unit
Hi, this is my first post!! I just gotta a reverb tank and reverb amp from working Hammond organ. It has a separate speaker for it. http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=160282162278 but what I wanna do is I'd like to make a reverb unit and use it with my garnet tube amp(about 40W i think) so can I just replace input and output with 1/4" jacks???? any resisters etc? any inputs would be appreciated! thank you!! |
| | #2 |
| Senior Member Join Date: Jun 2006 Location: California, USA
The amp needs a high level signal to drive it. Note that the auction says that it is driven from the speaker output. The amp you bought does not have enough gain to be driven directly from your guitar. It drives its own dedicated speaker. So...you cannot just change the jacks and use it as a stand alone reverb unit like the classic Fender 6G15 unit if that's what you were thinking. Regards, Tom |
| | #3 | |
| Quote:
so to increase the gain would be pretty hard too? thanx!! | |
| | #4 |
| Not necessarily. However, you would have to add extra amplification stages. The system you have is a different approach than is used in most guitar amps. You have not said what you really want. It may be fine for your personal use if set up as the seller described. But it's just one section of a larger system. Not a stand alone reverb system. Tom |
| | #5 |
Tom, thanx I see. Fender 6G15 is exactly what I had in mind when I saw this item. I guess I just jumped into to it without studying much about it. I only build a couple of pedals and fender bassman clone so...i need to study more. perhaps, i can compare the schmatics and layout of 6G15 with actual item and figure out? any input? thanx! |
| | #6 |
perhaps, could i use some resister to use as a dummy load? i just read somewhere..i can't seem to find anything like this conversion for guitar reverb on web anywhere... hmhmm |
| | #7 |
has anyone found anything like this online?
| | #8 |
This was right in the posting: BASICALLY YOU WILL NEED TO USE THIS WITH ANOTHER TUBE AMPLIFIER THAT IS NOT OVER 20 OR 30 WATTS. YOU JUST LOOP OFF OF YOUR EXISTING SPEAKER INTO THE SIGNAL INPUT ON THIS REVERB AMP. THERE IS THEN AN OUTPUT TO THE REVERB SPEAKER AND YOU WILL HAVE A VOLUME KNOB TO CONTROL THE AMOUNT OF REVERB YOU HEAR. IT'S VERY SIMPLE TO HOOK UP BUT IT IS A REVERB AMP AND REVERB AMP ONLY. IT IS TO BE USED WITH AN EXISTING AMPLIFIER. And, if I remember properly, those do just tap directly off the Hammond organ speaker in parallel, as my M3 did. BUT, I'm not advising tapping off a guitar amp output. I'll let someone else decide if that's safe. Brad1 |
| | #9 | |
| Quote:
anyone else? im too scared to hook it up try it now.. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| 6G15 stand alone reverb (PT and Reverb tranny qns) | tubeswell | Theory & Design | 5 | 08-29-2008 10:39 PM |
| Troubleshooting an RE-201 reverb unit | hovmod | Maintenance, Troubleshooting & Repair | 4 | 05-28-2008 11:42 PM |
| Vibro champ to Reverb Unit! | vibrato64 | Mods & Tweeks | 2 | 01-09-2008 09:28 AM |
| More gain from a 5G15 reverb unit | Nathan | Mods & Tweeks | 0 | 07-03-2006 10:33 PM |
