| | #1 |
| Senior Member Join Date: Jun 2007
| Slower speed
I have just finished building my first winder. Quite excited as I'm sure anyone who has done so can relate. I am using a sewing motor and footpedal. The footpedal is not adjustable as it simply connects or disconnects the power completely... there is not in b/t. Anyone know how I might hotrod a speed control w/ one of these? I tried a lamp in series but it clamped the current so much that the motor would not run at all.
| | #2 |
| Senior Member Join Date: Apr 2007 Location: Guelph, Ontario
Is this not a sewing machine pedal? Or, have you hooked up the wrong contacts somehow? Do you have a pic of the pedal and connections? Usually all sewing machine pedals are inductive and are variable.
__________________ www.copperheadpickups.com |
| | #3 |
| Senior Member Join Date: Jun 2006
I used a lamp dimming module from an old Torshire floor lamp, works great. http://users.isp.com/brad_anne/winder.htm I did end up adding the foot controller back on to use it for slow start-up, and now the lamp-dimmer control acts as a speed limiter. Last edited by RedHouse; 09-23-2008 at 04:27 PM. |
| | #4 |
Ok yeah I was gonna try a fan speed control I have laying around. Nice winder!!! thanks.
| | #5 |
| Senior Member Join Date: Sep 2008
I use a "router speed control" that I bought from harbor freight for $14.99...you just plug the power chord from your "Winder" into it and then plug the speed control into the outlet. It has a very fine adjustment so you can get a good slow start... Go to harbor freight and search for Item number: 43060 http://www.harborfreight.com/cpi/cta...emnumber=43060 Last edited by tboy; 09-29-2008 at 10:07 PM. |
| | #6 | |
| Quote:
That wouldn't work for me, I have other things powered from my line cord, but it should work for anybody running just the winder motor. | |
| | #7 |
You're right...I have my motor on a separate plug from my counter.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to open Kay Speed Demon | GlennW | Pickup Makers | 14 | 07-30-2009 03:46 AM |
| 5G9 Speed control | tubeswell | Tweed Builders | 1 | 04-12-2008 09:58 AM |
| Does winding speed make a difference? | madialex | Pickup Makers | 11 | 10-17-2007 02:56 PM |
| Reducing motor speed - how? | dpm | Tools and Coil Winding Gear | 8 | 07-29-2007 05:11 AM |
| Slower Vibrato on Vibro Champ?? | vortex | Maintenance, Troubleshooting & Repair | 4 | 11-14-2006 02:14 AM |
