Results 1 to 25 of 25
Like Tree2Likes
  • 1 Post By stingray_65
  • 1 Post By GregS
Thread: Tube Socket Holes
    Sep 2008
    296
    Tube Socket Holes
    Is a chassis punch necessary to do a reasonably neat job of making tube socket holes in a chassis or could a drill bit do a good enough job of this? The reason I ask is chassis punches seem to be very expensive.
    Thanks,
    Greg
    Senior Member zhyla's Avatar
    Jul 2008
    108
    Cheapest tool for this I could find:
    http://www.acehardware.com/product/i...Id=37733771534
    There's a mandrel that it attaches to so that you can mount it on a drill. The two large holes on the lower-left of the attached I cut with this tool. Works fine, but you have to go slow at first until it gets a little groove started. Greenlee punches are more convenient but what do you want for $10 .
    Jag
    Jag is offline
    Senior Member Jag's Avatar
    500
    I've used hole punches and hole saws. I find the hole saw works fine (actually I like it better for steel chassis). Make sure you get a bi-metal hole saw or you'll be going through them failry quickly.
    I prefer a step bit for holes 3/4" and smaller.
    As Zhyla said, go low RPM to start.
    Sep 2008
    220
    Hi Greg!
    I've not built an amp before, however I do have over 2 decades of metal fabrication experience.
    depending on your chassis material and thickness and the diameter of the hole, you could use a twist drill bit.
    I wouldn't, an inexpensive alternative to a die punch is a hole saw.
    a drill press is a huge plus here , but in lieu of that a VARIABLE speed hand drill can be used.
    back the area you want to drill with a piece of 3/4 plywood or other such thing.
    if your chassis is aluminum, use kerosene or charcoal lighter fluid for a lubricant.
    if your chassis is steel use a light machine oil or transmission fluid for a lubricant
    if it is stainless steel you need a special sulfur based lubricant like RIDGID DARK PIPE CUTTING
    in all casses turn the hole saw SLOW AS POSSIBLE.
    if your using the hand drill "orbit " your drill. that is to say tilt the drill slightly and slowly rotate the drill in a CCW orbit.
    optimlaly the hole saw should hit flat againt the metal, this is un realistic using a hand dril, so deliberatly only let a small section of the saw touch the metal at one time and orbit it.
    beware what is happening when you "break through"
    this is when the hole saw really grabs.
    go slow
    real slow
    practice on a few scraps before you go ahead with your chassis.
    if i'm unclear on anything here let m know i'll be happy to walk yo through it
    J M Fahey likes this.
    Supporting Member tubeswell's Avatar
    Feb 2007
    Wellington NZ
    3,774
    Blog Entries
    1
    Or you can look around 2nd-hand tool shops and find chassis punches for good prices. That's what I did
    Sep 2008
    296
    Thanks a lot for the info from everyone. I think the hole saw will likely be the approach I'll take.
    Stingray_65, your tips are very helpful as I don't have a drill press and will be using a hand drill. Good to know these things rather than learning the hard way!
    Thanks again,
    Greg
  7. #7
    Senior Member Mandopicker's Avatar
    Jul 2007
    San Ramon, CA
    167
    I have had excellent luck with step-bits. Real clean holes.
    Not terribly expensive, but as you all know...build one amp and you can't stop with building more.
    The investment in a good set of punches or step bits will pay for themselves in no time, and assure a quality build.
    Mandopicker
  8. #8
    daz
    daz is offline
    Jan 2007
    1,508
    I did my first 2 with hole saws and it was a biotch. then someone told me about step bits and pointed me to harbor freight where i always seem to find great deals. sure enough they had a 2 pack, one that goes to i think 7/8" and the other 1-3/8". The larger one was much slower for some reason, even on the steps that were the same size as the smaller bit. the smaller one went thru like butter on aluminum.
    a customer who saw me looking at them told me he's bought them there and his have been used forever and still work. And the 2 pack was $20. Other places charge as much as 30 or 40 bucks for one. Anyways, i did every holein the amp from pot holes to the cap can with them. they aren't perfectly clean like a punch, but they're fast and clean enough. Put it this way....when i look at the amp i never even notice the quality of the hole edges. if you look for it then you'll see they aren't lazer cut or whatever, but they're perfectly fine. the hole saws i used on the first 2 took forever, were a pain, and the holes weren't nearly as clean. Thats my experience anyways.
    By the way, HF also had a set of punches for $15 i think it was. But only 2 of them were of a usable size....one the same as a 9 pin socket and the other for octals. But i would have had to use something else for the cap can and other holes, while the step bits were used for every single hole in the amp ! Highly recommended unless lazer clean holes are a must for you. then i'd say you'll need to bite the bullet and pay the big dollars.
  9. #9
    Sep 2008
    296
    The step bit sounds ideal. I'm not exactly familiar with what it is but I assume it's a bit that gets progressively larger in steps. Correct? Are they available in regular hardware stores? Is Harbor Freight an online store?
    Thanks,
    Greg
  10. #10
    daz
    daz is offline
    Jan 2007
    1,508
    exactly. The $15.99 set is what i got. they will cut any size up to 1-3/8, which is a tad under a cap can but big enough for octals. A can hole just needs to be enlarged a tiny bit with a dremel.
    http://search.harborfreight.com/cpis...+bit&Submit=Go
  11. #11
    Sep 2008
    296
    OK, great.
    Thanks
  12. #12
    Sep 2008
    23
    Unibit's work great and can be used with a simple drill press (which has a million uses).
    For real chassis punches, you can get used Greenlee Radio Punches for less than $10 a piece. Unlike modern Greenlee punches which are sized for conduits and such, the radio punches are the (considered obsolete) tube socket sizes like 1-3/16" and even square-shaped transformer punches.
  13. #13
    Sep 2008
    296
    I have a set of step bits ordered that should arrive any day. My chassis is steel. I was wondering if I should lubricate the bits when drilling and if so what is the best lubricant to use.
    Thanks,
    Greg
  14. #14
    Feb 2007
    Wellington NZ
    3,774
    Blog Entries
    1
    Quote Originally Posted by GregS View Post
    Thanks,
    Greg
    Don't use anything flamable (unless you want scorch marks)
  15. #15
    Sep 2008
    220
    OK
    first thing to remember is the bigger the hole the slower (rpm's) you go
    use a variable speed drill
    second is the bigger the hole the liklier it will grab and swing the chassis toward you at a hip bruising, chasss twistng speed.
    its best to use ANY lubricant even water! if it smokes your pushing too hard or going to fast.
    you wont want to clamp your chassis in a vise, so if you have a wooden bench just cleat it between some old lumber (2x4's) screwed to the bench
    in lieu of that maybe clamp some boards to your table top, just make sure your chassis wont rotate.
    not knowing your chassis depth, you may want to check to see the length of your bit vs the depth of your chassis and the liklihood of it drilling into your workspace.
    LOL with all that said you will spend more time setting up than you will drilling
  16. #16
    Old Timer defaced's Avatar
    Dec 2006
    York Pa
    1,262
    Any tapping or light machine oil will work. A small container of it will cost like 5 bucks at a hardware store and last you years. You can also use light engine oil like 5w-30.
    In high school shop, the cutting fluid for our automatic hack saw was Elmer's glue mixed with water.
    The other thing to note is to use a pilot hole, otherwise you risk your bit walking while you're trying to start the hole. I typically use an 1/8" pilot.
    -Mike
    Humor is the best alternative to serial killing. - Chuck H
  17. #17
    Sep 2008
    296
    Thanks a lot for all the replies. That's very helpful.
    Greg
  18. #18
    Sep 2008
    296
    I finally got this done and it was a success - thanks to the help and suggestions I received here in this thread.
    I used the step drill bit method. When testing hole sizes on scrap metal I found that the 1 1/8" size had a bit of a loose fit for my sockets and 1" was too small of course. When drilling the 1 1/8" size, rather than drilling right through, I stopped the drill numerous times and tested fit with the socket until it had a nice snug fit. The edges of the holes aren't quite as neat as a result but I think it's a worthwhile compromise.
    The tip about attaching wood blocks to the workbench to stop the chassis from rotating if the bit grabs really saved the day here as it did grab big time on the last two holes. I think the last two holes were more of a problem because I started from the corner of the chassis where it's more rigid and worked towards the middle. Had I started with the middle holes the grabbing might have been less of a problem as the chassis would have been more rigid before the other holes had been drilled. Maybe this experience might benefit someone else doing it the same way.
    Anyway, I just wanted to say I was able to get this right the first time because of the help and suggestions I got here.
    Thanks again,
    Greg
  19. #19
    Sep 2008
    296
    Sorry, double post.
    Greg
  20. #20
    Sep 2008
    220
    Congrats!
    most any aspect of any construction project becomes simple and do-able for anyone once they posses the knowledge and tools.
    with that knowledge and then the experince of having done the task at hand you gain skill.
    so very glad you didn't have to gain the skill of dodging a rapidly spinning workpiece LOL but you will if you make enough holes enough times in sheetmetal with a drill
    hope to see some pics of your handy work soon
  21. #21
    Sep 2008
    296
    Ok. The edges of the holes aren't perfectly clean but, like I said, I tried to drill a size in between steps to give the socket a tighter fit. I have found that the hole centre tends to drift slightly as I drill successive steps even if I started it in exactly the right place. The drift was consistent for each hole though so they are perfectly aligned anyway. I guess a drill press is a must if accuracy is really important.
    I'm trying to upload a picture. Hope it works.
    Greg
  22. #22
    Dec 2006
    York Pa
    1,262
    Bits will still walk, grab, and not work perfectly even on a drill press because of the slop in most drill presses movements and the nuisances of how a drill bit cuts. It looks like you did a hell of a good job.
    -Mike
  23. #23
    Sep 2008
    220
    SWEET!
  24. #24
    Nov 2012
    5
    Tube sockets were typically mounted in holes on a sheet metal chassis and wires or other components were hand soldered to lugs on the underside of the socket. In the past, printed circuit boards were introduced and tube sockets were developed whose contacts could be soldered directly to the printed wiring tracks.
  25. #25
    Oct 2007
    Buenos Aires, Argentina
    4,467
  1. need tube socket layout for a realistic af-15 amp
    By GEORADIO in forum Vintage Amps
    Last Post: 05-04-2008, 09:30 PM
  2. Dirty Tube Socket Question
    By Paleo Pete in forum Repair and Restoration
    Last Post: 04-15-2008, 12:00 PM
  3. Soapbar P-90 covers with no holes?
    By David Schwab in forum Pickup Makers
    Last Post: 03-20-2008, 11:30 PM
  4. Ampeg vl-502 tube socket short?/fire
    By davis1866 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-28-2008, 08:49 PM
  5. Beer battered deep fried tube socket
    By Ptron in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-04-2006, 08:00 PM
