Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 10-14-2006, 08:57 PM   #1
Deluxe Reverb LDR
Hello all,
I was wondering what an appropriate resistance swing would be for the LDR in the vibrato section of the Fender Deluxe Reverb AB763 circuit? Do any manufacturers make similiar LDRs to the original? I wouldn't imagine it would matter that much if the LDR's swing was too different provided the surrounding resistances where appropriately scaled to allow the LDR's change to be sufficient.
Thanks for any input.
-David
weeping6 is offline   Reply With Quote
Old 10-24-2007, 02:07 AM   #2
oahu's Avatar
Fender LDR
hello.
you can get the ldr, fender uses here:
http://www.mojomusicalsupply.com/ite...797&id=4113400
http://www.tubesandmore.com/
http://www.tubeampparts.com/Merchant...roduct_Count=0
or if you're in europe:
http://www.tubeampdoctor.com/product...roducts_id=268
several other suppliers may have it.
also this might be interesting for you:
http://www.terrydownsmusic.com/techn...o_circuits.htm
i also have to change the ldr in my silverface deluxe reverb, but that's the least problem with this amp. this project will be much fun...
anyway, hope this helps.
greetings from vienna
oahu is offline   Reply With Quote
Blackface Deluxe Reverb Tank? Watto Vintage Amps 7 10-29-2006 04:21 PM
Deluxe Reverb RI help lrs11 Maintenance, Troubleshooting & Repair 7 10-13-2006 01:17 AM
Filtering in Silverface Deluxe Reverb Doug Mods & Tweeks 7 09-20-2006 04:49 PM
intermittent problem on a deluxe reverb kaiomenos Maintenance, Troubleshooting & Repair 3 07-06-2006 05:15 AM
SilverFace Deluxe Reverb Conversion Corona Blue Maintenance, Troubleshooting & Repair 6 06-16-2006 07:31 PM
