Old 10-07-2008, 03:21 AM   #1
Marina's Avatar
Question ESR Meter
Hello,
I was just wondering if anyone could reccomend where I could get an ESR meter at a good price, or even a kit that I could build. I really need one for work.
Thanks,
Marina
Marina is offline   Reply With Quote
Old 10-07-2008, 04:48 AM   #2
What do you need it to do? What precision do you need? What conditions do the caps operate under? Are you characterising for match, comparing different vendors or doing maintenance and repair?
And what's a good price. $500 for a $1200 unit? Or just something under $100?
MCM sells this basic unit for $200.
Look for an older Sencore "Z-meter" in the LC series. I found a couple LC53 models on ebay like this one
In fact plug ESR Meter into ebay search and find a number of types.
Here is an interesting site for ESR meters:
http://members.ozemail.com.au/~bobpar/esrmeter.htm
Here is a simple project meter:
http://ludens.cl/Electron/esr/esr.html
Google ESR Meter for more hits than you'll know what to do with.
Old 10-07-2008, 05:19 AM   #3
Lifetime Member
I have the Dick Smith project kit one. I love it. It's exactly what is needed for debugging old tube amps.
R.G. is offline   Reply With Quote
Old 10-07-2008, 04:13 PM   #4
Personally, I have found ESR meters to be rather useless, but that's just me.
__________________
John R. Frondelli
jrfrond is offline   Reply With Quote
Old 10-07-2008, 06:16 PM   #5
The LC53 doesn't do ESR does it? At least it doesn't spec it in the cut sheet I found. Just says value, dielectric absorbtion, and leakage. I have a couple LC77s, and they do ESR. Just be sure an' do the lead short/open null cal first or it'll throw off the ESR readings.
__________________
Gtr_tech is offline   Reply With Quote
Old 10-08-2008, 12:34 AM   #6
Supporting Member
http://www.anatekcorp.com/testequipment/esrcompar.htm
JoeM is online now   Reply With Quote
Old 10-08-2008, 02:09 AM   #7
Marina's Avatar
I'm in maintenance & repair. Not very sophisticated. Looking for something under $100. I'm used to using one that just has an analogue meter that will let you know if the cap is dried up. I wasn't aware there was much more. I need one of my own for my part time job.
Old 10-08-2008, 02:28 AM   #8
Marina's Avatar
Quote:
The ESR meter has been quite helpful to me on many occasions. However I can remember one instance when the ESR meter indicated the capacitor was good, but the ohm meter showed it only discharging in both directions. It was bad, and replacing it straightened out the problem in the circuit.
Old 10-08-2008, 02:31 AM   #9
Marina's Avatar
Thanks Joe, this is great! I think I'll get that Blue kit.
Old 10-08-2008, 02:59 AM   #10
Gtr, and Marina, if the LC53 didn't include ESR, I apologize. I know the later ones did, I assumed the 53 had it as well.
Personally I never saw the need for ESR readings. It was far more efficient to me to just replace suspect parts than to take the time to characterize them. And usually from circuit function we can tell if the parts are bad.
Old 10-08-2008, 05:21 AM   #11
Exactly! This comes from experience.
Speaking for myself, and most likely for Enzo and other experienced techs here, I find that the older I get, the less paraphernalia I need to troubleshoot and repair most units.
Having said that, the meter that we have around "just in case" is a Wavetek LCR55. Sure, it has a great cap and inductor checker built in, but the handiest function is that it has a 20Ω setting that will read down to fractions of an ohm. This is handy when trying to find those .1uF decoupling caps that short on opamp rails. It eseentially lets you find the path of least resistance.
__________________
John R. Frondelli
Old 10-08-2008, 08:31 AM   #12
Oh lord yes. You open up a 32 channel mixer with 15v rails loaded down, and there are at least a half dozen op amps per channel plus all the master section ones and each one has a little bypass cap across it and ONE of those is shorted. What a pain.
The most likely use I have for an L/C meter is for inductors. Crossover inductors come in even units like 3mHy, 4mHy etc. and we need a 3.6mHy coil. Buy a 4 and unwind part of it. watch with the L meter.
Old 10-08-2008, 09:37 PM   #13
It does help to check the ESR of output coupling caps in older stereo recievers/amplifiers that used that type of circuit. Caps that go high ESR there will dull high freq response. I have a couple customers who bring me old Marantz, Sansui, etc stuff and the lower powered ones are sometimes cap coupled output. Of course we don't see this in pro audio stuff.
__________________
Old 10-08-2008, 11:12 PM   #14
OR, you can use the technique I learned at Behringer in Germany. Smoke 'em out by bypassing the PSU regulators and feeding the opamp circuits raw B+. Most of the opamps will take +/-30V, so you won't harm them, but the shorted cap will just snap open in a little blaze of glory!!! Cool to watch. All of our house PSU's have regulator bypass switches installed. We'll also do this on the bench with open modules on a triple DC supply. I always say "Cook it 'til it dies!".
__________________
John R. Frondelli
Old 10-09-2008, 12:51 AM   #15
NickH's Avatar
I am using a Peak Atlas ESR - Capacitor Analyser - Model ESR60
http://www.peakelec.co.uk/acatalog/jz_esr60.html
I am an utter muppet, so it really helped me to be able to check the caps in circuit quickly, I love the thing...
No doubt when you really know what you are doing they are less useful, but this one has saved me LOTS of soldering
NickH is offline   Reply With Quote
Old 10-09-2008, 04:28 AM   #16
Well....if yer a muppet...which one are you Sam the eagle?
__________________
Old 10-09-2008, 04:48 AM   #17
olddawg's Avatar
I dicked around with ESR meters for years, the expensive Sencores, etc. I was using them to identify dried out caps in camcorders. Ultimately the only true test I found was replacement of the caps. I have wasted too much time trying to verify a cap when just replacing them is a better option. Keep in mind I was testing dozens of caps at a time in circuit.
olddawg is offline   Reply With Quote
Old 10-09-2008, 09:14 AM   #18
NickH's Avatar
Quote:
Beaker for sure !
Cheers
N
Old 10-31-2008, 02:55 AM   #19
Marina's Avatar
Got my blue meter & checked it out tonight. I opted for the preassembled & tested unit after all, & I'm very pleased with it. It's simple, straightforward, & has a chart on the front to assess what you're reading. Couldn't ask for more at the price. Thanks again, Joe!
Old 10-31-2008, 03:38 AM   #20
Quote:
Originally Posted by Marina View Post
.....to asses what you'er reading.....
Who ya callin' "asses"???
Couldn't resist!
__________________
John R. Frondelli
Old 10-31-2008, 03:56 AM   #21
Marina's Avatar
Couldn't resist!
Assess. Sorry!
Old 10-31-2008, 06:17 PM   #22
Supporting Member
I'm glad you found that info useful.
VU Meter Yossarian Theory & Design 3 03-19-2008 04:39 PM
ESR question Fender reissue Bassman Garydean Maintenance, Troubleshooting & Repair 0 03-11-2008 11:52 PM
Wiring a VU meter danielzink Mods & Tweeks 29 12-30-2007 02:15 AM
Weston Ma Meter stokes Music Electronics 8 04-16-2007 06:47 AM
looking for decent esr meter tonezoneonline Music Electronics 2 03-27-2007 11:58 PM
