| | #1 |
| Member Join Date: Jul 2006 Location: Upstate NY
| DR Treble response
I have a SF DR that I put a 25k pot off the bass pot for a midrange control and it works fine. I've done this many times but this time it seems that there is no turning down the treble response,in other words it is like it is always on and has minimal slightly noticable effect when turned up. I suppose I could change the mid pot to 10k but it is just strange to me because this has never happened before.....Any ideas? Mike |
| | #2 |
| Senior Member Join Date: Sep 2006 Location: Chicago
One worthwhile suggestion would be to check and see if your Deluxe has a ceramic capacitor on the [Vibrato channel] volume control. This is essentially a permanently ON bright switch. I, personally despise the sound of bright switches on Fender amps, they tend to bring out maximum harshness. With the capacitor removed, the amp sounds much sweeter.[/SIZE]
| | #3 | |
| Quote:
| | #4 |
??????No! NOT a cap in the Vibrato network. I was referring to a cap that is mounted on the VOLUME CONTROL of the Vibrato CHANNEL. There's no need to dismember the vibrato ckt.
| | #5 |
| Duh. sorry man...that was really dumb. I should have known better...I thought it was "interesting" cause I'd never heard of that before, but my excuse is that I was at work and read it quick.... anyway, I've already removed the cap on the volume control.
| | #6 |
How about checking out the treble pot. If it is open at the low end, then it won't diminish the highs when turned. Also check the soldering, Since you were in that area of the circuit soldering, it is possible you cracked the solder on existing parts. Carefully check the solder on all the EQ controls.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Treble Control popping noise | dpierce05 | Maintenance, Troubleshooting & Repair | 1 | 09-11-2008 02:50 AM |
| Treble distortion | Paul P | Theory & Design | 6 | 04-02-2008 09:58 AM |
| Treble and Bass pots not right. New build | MickeyB | Debugging Your Build | 4 | 03-28-2008 04:18 AM |
| Treble distortion | Paul P | Maintenance, Troubleshooting & Repair | 8 | 03-14-2008 04:07 PM |
| Fender 350k tapped treble pot | Fred G. | Guitar Amps | 7 | 05-05-2007 07:53 AM |
