That was my first thought, turn R37 into a 1M pot, or a pot and a resistor if you want limits.
SInce the reverb transducer is in parallel with that 4k7 resistor already, swamping it with a 680 ohm resistor sems to me like a brute force method. I would try increasing R35. What happens if it becomes 470 ohms instead of 47? Or make it a 1k (or 200 ohm or whatever works) pot wired as a variable resistor.
LinkBack URL
About LinkBacks
Yes, I think that some compromises were made to the tone stack and to the shared tube stages to accommodate the Clean and the OD channel. But I was not limited by that restriction since there is no OD channel in my amp. I call it a poor man's Maz 18- put a nice pedal or two in front of it and you can get all of the dirty sounds you want as well...
