Results 1 to 7 of 7
Thread: Hall Effect Counter?
    Jun 2008
    21
    Any one have schematic/drawings. I have a spare cub3 can't find any simple schematics to run the hall to the counter.
    THANKS!
    Supporting Member John_H's Avatar
    Jul 2006
    305
    I experimented with a hall sensor, but didn't have good results. I'll give you a schematic for an optical switch that you can build cheap, and easy though.
    Supporting Member belwar's Avatar
    Jul 2008
    1,065
    Quote Originally Posted by John_H View Post
    OooOoo Can you post that here? Im interested in that myself
    Jun 2008
    21
    COOL!
    The hall will take some kind of voltage so will optic!
    So I'm game!
    I just like everyone, I'd like to try both. Even from what everyone eles says optic is the way to go.
    So eveyone post what they got!!
    THAANKS!
    Jun 2008
    21
    I have found this!
    Seems the 78LO9 will regulate the voltage to 9volt? But with out the 78LO9 9 volt straight could be used?
    The opb380 seems to be hard to find!
    THANKS !!!
    Jul 2006
    305
    Here's what I made for my optical switch. I'm using a cub1 counter. It requires a TTL signal less then 3v@1kr to not damage the batteries. That's why the voltages are what they are. It should work well for other counters too. All of the parts for this should be available at Radio Shack for less then $10.
    The switch on the right is the one described
    The switch on the left in the picture uses the same circuit to trigger a reed relay. This makes it possible to use it with a pedometer, or a calculator. I'm still experimenting with this so try it at your own risk.
    Parts:
    3 X 10 ohm resistors
    1 X 1k ohm resistor
    276-142 Matched emitter/detector set
    7805 Voltage regulator
    Disclaimer; This is what I came up with fumbling around on a breadboard, and is open to all criticism. It's working good for me.
  7. #7
    Jun 2008
    21
    Hi!!!
    COOL! I think i all ready have all the parts except the emitter/detector.
    The drawing will come in handy! Thanks!!!
    THANKS!!
  1. Reed switch / calculator counter
    By Meowy in forum Pickup Makers
    Last Post: 01-30-2008, 12:34 AM
  2. Hooking up a counter
    By Brian Porter in forum Tools and Coil Winding Gear
    Last Post: 12-15-2007, 10:26 PM
  3. That old down counter again
    By RedHouse in forum Tools and Coil Winding Gear
    Last Post: 12-09-2007, 03:01 PM
  4. Turn Counter?
    By Aka Nameless in forum Pickup Makers
    Last Post: 06-14-2007, 08:31 AM
  5. Hall Effect Sensor?
    By Dave293 in forum Tools and Coil Winding Gear
    Last Post: 01-26-2007, 06:40 PM
