| | #1 |
| Member Join Date: Apr 2008
| My first Build (pics & clip)
This is my fist stab at building an amp from soup to nuts. It's all SS (sorry tube guys) but I'm happy with the results. It's quite small and powered by 12V DC. Here are the details:
Also, here's a sound clip a friend recorded for me. Fair warning, it's about 2.5MB. http://www.mr2-power.com/Hurricane_test_2.mp3 ![]() ![]() ![]() |
| | #2 |
Hmm... no comments at all? Must be pretty bad |
| | #3 |
| Supporting Member Join Date: May 2006 Location: Texas USA
Cabinet looks really nice. You need to find a source of industrial grade screws though. Sorry I don't have the bandwidth to listen to your sound clip. What does the Category control do?
| | #4 |
Thanks so much for the comment. Yeah, the screws are all from Home Depot/Lowes. In the future I'll probably order everything from McMaster so the heads sit more flush with the finish washers. But I did make sure there are no screws into wood. Everything is either bolted through with a nut and washer or a machine screw into a threaded insert secured in the wood. I hate wood screws... They always end up stripping out. The category control adjusts the gain from about 20x to 200x. Since the theme of the amp was "hurricane" we played around with some of the terms. The "Storm surge" switch above the input jack provides an additional gain boost but in a different way. The LM386 chip that I used for the preamp actually sounds pretty good when clipping (as opposed to most normal opamps). I'll have to cut down the clip to some smaller segments so you can have a listen. The guy I built it for has been using it quite a bit for direct recording (just routing the preamp output into a protools direct in box) so I'm going to throw together another box that just has the preamp section in it. Should be tiny and serve his purposes well. Last edited by armstrom; 11-06-2008 at 02:52 AM. |
| | #5 |
Ok, I've cut down a couple of snipits from the larger mp3. They should be managable for pretty much any connection. All of the clips are with the first volume control up about half way so much of the guiar signal is being attenuated. There is quite a bit more drive and grit available if you crank the volume knob up but my friend was recording this in his condo and didn't want to annoy his neighbors -First clip is with the gain up about half way (category 3 or so). -The second clip is with the category (gain) all the way up (Cat5) -The final clip leaves the gain all the way up but turns on the "storm surge" switch for an additional gain boost. |
| | #6 |
Sorry I didn't comment earlier, I lost track of this thread. I listened to the mp3's and these are my comments. Overall the amp sounds pretty good. The dynamic response of the power amp is good. There is no blocking distortion and transients are crisp. I didn't hear any bad things from the power supply. The speaker sounds good. The preamp is very clean. Sounds like an opamp with plenty of headroom. There is a certain distortion you get running a clean guitar thru a 12AX7. If you train your ear, you will start to hear it anytime someone plugs directly into a Fender tube amp with the volume on 2. Your amp doesn't make this sound and I'm not saying that's a bad thing. I think this is one of the things people mean when they say an amp sounds "warm". One way to warmup your amp would be a preamp made with JFETs or some other not so perfect devices or circuits.
| | #7 |
Thanks so much for the comments. Yeah, this amp was really designed for a blues harp player but the only person I could have test it plays guitar My friend has been doing some direct recording using the preamp out jack and I'm hoping to get my hands on some of those clips to share |
| | #8 |
I was thinking of making a source follower that would add the right kind of distortion to warm up the signal a little. The problem is that FETs are not spec's very tightly, IDss can vary over a 5 to 1 range. Any circuit can go from good to bad even with the same company's parts. FETs distort more when Drain current varies. In oscilloscopes they like to use JFETs with constant current sources for low distortion. What FET are you using? By changing the biasing and source resistor you should be able to dial in a little warmth. |
| | #9 |
It's an MPF102 . I considered converting it into a common source gain stage but it's too late now, this amp is done and out the door to its new owner |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| WGS Alnico clip | teleamp | 5 E 3 | 4 | 07-06-2008 04:54 AM |
| 5F11 Vibrolux build - pics | Crawfish | Tweed Builders | 5 | 04-21-2008 02:18 AM |
| updated new build pics/schemo 6AU6 | Alexander | Theory & Design | 6 | 02-18-2007 05:11 PM |
| new build/pics with 6AU6A pentode preamp | Alexander | Theory & Design | 12 | 01-25-2007 08:51 AM |
| 5D3 Clip | s2amps | Tweed Builders | 1 | 07-21-2006 09:15 PM |
