Go Back   Music Electronics Forum > Amplification > Guitar Amps
Guitar Amps General discussion about amps
Old 10-19-2006, 11:25 PM   #1
Satamax's Avatar
Location: Southern french alps, right by the Italian border
Talking Variable cathode bias?
Hi everybody!
Well, any problem with using a pot in parallel with the cathode bias cap of a 5E3 to make a variable cathode bias? I was thinking of 470Ω and a 10K pot in parallel for example.
Thanks.
Bye.
Max.
Satamax is offline   Reply With Quote
Old 10-20-2006, 01:09 AM   #2
JC@
JC@'s Avatar
I can't see why not. Even a little trimer pot would be ok I believe.
JC@ is offline   Reply With Quote
Old 10-20-2006, 02:50 AM   #3
This is for the 6V6 tubes I take it? Consider adding another resistor in series with the pot to provide a lower limit to the resistance of that leg. Without that the pot can be rotated to a very low resistance killing either the pot or the tube.
The 5E3 had a shared 250 ohm cathode resistor, if you wanted a range of adjustment from 200 ohm to 350 ohm using your fixed 470 ohm cathode resistor you could add a parallel 1k pot and 330 ohm safety resistor.
Pots and trimmers can get noisy, It'll probably be fine but keep it in mind in case you have some noise problem later and need to know where to look.
carl gigun is offline   Reply With Quote
Old 11-11-2006, 12:19 AM   #4
Instead of a pot,I have used adjustable wirewound 500ohm 5watt and 10 watt Ohmite resistors.You can adjust for different current draw with different tubes,no problem with noise as Carl pointed out,and less parts to deal with.
stokes is offline   Reply With Quote
Old 12-12-2006, 05:24 AM   #5
Combination bias got a bad rep due to some ugly silver face fenders, but I actually like to do this for these types of amps. That way you can pick the amount of bias shift due to the cathode resistor while still getting the tubes to bias were you want them by adding a little negative grid voltage in.
PaulC
PaulC is offline   Reply With Quote
Grounded Cathode LastManOnEarth Theory & Design 4 12-21-2008 05:43 AM
4X6V6 Cathode Bias stokes Theory & Design 27 03-08-2007 05:13 PM
Cathode follower cathode resistor question Mark Buckingham Theory & Design 9 10-10-2006 12:12 AM
