| | #1 |
| Member Join Date: Sep 2008
| choke VS resistor
I have a SF pro reverb I rebuilt. I changed out both transformers but instead of a choke the amp had a 25 watt 1K wire wound resistor. I just replaced it with a new resistor. Is it worth replacing the resistor with a real choke tone wise? If I replace it is a standard Fender choke OK or something from Mercury Magnets better? Rymac |
| | #2 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
I take it you mean a choke in a Pii filter from the screen supply-node onwards? The idea of a choke is to improve filtering in the B+. It will be quieter than a resistor filter, and there shouldn't be any hum. Compared to a resistor, it also has relatively little DC resistance, so you get more DC voltage at the screens (so you might need to add 470R-1k5 3W-5W screen grid resistors if the screen voltage rises more than 3-4VDc above the plate voltage in each tube), as well as increasing the B+ throughout the pre-amp, which increases the signal headroom (i.e.; if you don't change anything else about pre-amp stages) and so gives a bit more chime. The choke should be rated for enough current - if it is just for the screens and pre-amp B+, then 40-50mA will be fine.
__________________ Building a better world (one tube amp at a time) |
| | #3 |
Didn't we just have like two threads on this exact topic within the last week or so? Do a search.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Choke/resistor switch? | daz | Theory & Design | 19 | 10-15-2008 10:35 PM |
| Choke question | daz | Theory & Design | 18 | 08-19-2008 07:11 PM |
| Can i replace choke with a resistor? | daz | Theory & Design | 4 | 05-20-2008 07:48 PM |
| Resistor in series with choke | Paul P | Theory & Design | 10 | 05-18-2008 07:06 AM |
| choke question | daz | Theory & Design | 2 | 05-09-2008 08:05 PM |
