| Music Electronics General discussion about music electronics |
| | #1 |
| Junior Member Join Date: Sep 2006 Location: Ca
| heater current question
Hey guys, if I use one side of a 12a-7, and figure out which of heater pins 4 or 5 operate in that section. Then, operate that heater at 6.3v, how much current will it draw? .3A or .15 A? |
| | #2 |
Current is the same throughout a series circuit. The .15A in the 12v arrangement doesn't change when you consider only half. All the 12v arrangement is is two 6v heaters in series, each drawing .15A - the SAME .15A flows through both. In parallel across 6v, EACH side draws its own .15A, whuch in parallel adds to .3A.
| | #3 |
Enzo, hello! Thank you once again for your help, I know it's a basic question. Though I have built many amps, I didn't know the answer to that one. It's never mentioned in any of the tube data, and I could not find it in any of the many books I have. I posted this question about a year ago and received two conflicting answers. I guess that's the reason it's not mentioned in the tube data. No sense in being redundant, silly me. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Transformer current draw for 2xKT88 | clyde1 | Theory & Design | 3 | 10-16-2006 06:19 PM |
| Heater Voltage & Todays Tube Recto's | Amp Kat | Theory & Design | 6 | 09-23-2006 02:57 PM |
| Using 1r to measure plate current | loverocker | Theory & Design | 16 | 08-23-2006 08:41 PM |
| Wire and voltage/current requirements | AtomicMassUnit | Theory & Design | 7 | 08-23-2006 07:22 PM |
| PT current rating for 6L6 in Brown Princeton | pete_b | Tweed Builders | 2 | 06-13-2006 09:31 PM |
