| | #1 |
| Senior Member Join Date: Jun 2007
| Les Paul issue
Hey all, I just bought my first LP. It's named Guitar of the Week... it's a classic w/ a mahogany top. This guitar also has cream binding around the headstock. Another note. I'm having issues w/ the guitar on gigs. With my previous guitar (Matt Guitar Murphy Cort) I would dig in w/ some screaming bends and it would SCREAM! Note I'm using the Seymour Duncan Twin Tube Classic for my overdrive tones. So... When I'm soloing I go for that screaming bend and my new LP isn't delivering. It seems to me like there is some serious compression going on when I really want to dig in. I'm wondering if this is a pickup issue. Maybe the heights are off or the action/truss rod are not in an ideal place. Can someone tell me ideal pickup heights for PAF pickups and getting some screaming sustaining tones? |
| | #2 |
| Old Timer Join Date: May 2006 Location: Planet Mongo in the country of PAF
What pickups are in it? Really, you should put the pickups up as close as you can get them, Seth Lover himself said that. On the the neck I would put it less close but raise the screws some to get more definition...
| | #3 |
| Senior Member Join Date: Apr 2007 Location: sydney australia
so is the issue when you bend the note, or when you really dig in, or only when you do both at the same time? edit: sometimes bending a note you can casue the guitar to "fret out" which is when you push the string over the curved fretboard, causing it to get closer to the frets and at some stage touch. you are probably getting close and limiting the strings movement. this is usually a bigger issue with fenders, as they have tighter radius's on their fingerboards, but the shorter scale length on the les paul makes it easier to push the string further in a bend and getting the same effect. you can fix it by raising the action. if the neck is not set up right in terms of the fretboard, neck relief, level frets ect then getting a setup should fix it as well. this should probably be in the guitar tech section, as opposed to the pup section |
| | #4 |
I sat down w/ my other guitar and realized the action was 1/64 higher but the t-rod was in same spot. Just for kicks I set my LP up just like the Cort and that night at the gig it was magical... Wow it never REALLY hit me like that that the string height being too low can really have quite a negative affect on the string movement... especially on the tongue. Now I can really dig in and the bends sing just like they used to. I will raise the pickups Possum... thanks. Oh, they're 57 classics. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| les paul noise | Valvehead | Guitar Tech | 11 | 12-09-2009 09:11 AM |
| My Les Paul Forums | Spence | Pickup Makers | 36 | 09-06-2008 08:19 AM |
| Les Paul - HB | Enzo | Lobby | 4 | 06-11-2008 10:33 PM |
| Les Paul Wiring | spartadrive_in | Guitar Tech | 21 | 04-04-2008 10:04 PM |
| HB Suggestions for Les Paul | PlayItAll | Pickup Makers | 4 | 11-07-2007 07:18 PM |
