| | #1 |
| Senior Member Join Date: Oct 2006 Location: Mid Wales
| 5E8-A tweed twin. Volume cuts out at 8
I just finished a clone of a 5E8-A tweed twin and I'm now having some trouble with it. When the volume is set between 1 and 6 the tone is very thin and weak. It sounds similar to out of phase pickups. When the volume is set to 7 or 8 it cuts out even more and the amp becomes almost inaudible. When I turn it up to 9 the volume comes back and it sounds nice and full. When it's cranked to 12 it sound great but the volume is a little lower than you would expect from a 45 watt amp. It sound more like a 20 to 25 watt amp. The amp has the same problem on all 4 inputs. Anybody have any idea what might cause something like this? |
| | #2 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
Hmmm..., triple-check your wiring My only other thought is if it is a new build and the vol pot is erratic, you might have a dud, or some solder resin may have flowed into it when you were putting it together - try changing the volume pot maybe?
__________________ Building a better world (one tube amp at a time) |
| | #3 |
If it didn't do it on both volume pots then I would think that it was just the pot, but it does do it on both volume pots in exactly the same place. I guess it's possible that 2 pots suffer from the same issue but I think something else is more likely. It's probably something I screwed up in wiring but can't seem to track down exactly where the problem is.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Amp cuts out at loud volume | mattmacdonald | Maintenance, Troubleshooting & Repair | 4 | 09-15-2008 05:59 AM |
| 5E8 twin step by step guide? | nate_hiltz | Tweed Builders | 3 | 07-27-2008 12:20 AM |
| Peavey VT classis cuts out at high volume. | flashmiles | Maintenance, Troubleshooting & Repair | 8 | 11-09-2007 01:37 PM |
| Twin Reverb build cuts out when Volume all the way up | nicksorenson | Debugging Your Build | 6 | 05-20-2007 04:34 PM |
| Twin Reverb build cuts out when Vol Cranked | nicksorenson | Maintenance, Troubleshooting & Repair | 2 | 04-16-2007 02:38 AM |
