Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 11-01-2008, 02:15 AM   #1
Plate voltage Tung Sol 5881
I read this on tubestore.com
"There are some important things to know about the reissue Tungsol 5881 tube before you decide to use it. The Tungsol 5881 is a 23 watt tube and is rated for a maximum plate voltage of 400Vdc"
How do you measure plate voltage?
Will the voltage change with different tubes?
rymac is offline   Reply With Quote
Old 11-01-2008, 02:55 AM   #2
Supporting Member
Quiescent plate (DC) voltage is measured from the plate (pin) to (the chassis) ground. It may change little with different tubes of the same type.
When the grid is being fed with a VAC signal, the plate voltage (on a conventional gain stage) will change in inverse proportion to the grid voltage.
__________________
Odd trouble with new Tung Sol 12AX7's hasserl Maintenance, Troubleshooting & Repair 11 05-04-2009 05:05 AM
12ax7 Tung Sol(new) Problem hal Tubes (Valves) 6 04-06-2008 07:24 PM
Tung-sol RI 6550 how much can it take? Steve Conner Tubes (Valves) 1 03-22-2007 03:22 PM
tung sol 12ax7 brit84 Tubes (Valves) 0 10-31-2006 07:47 AM
Tung Sol 6V6 reissue H Chandler Tubes (Valves) 5 05-26-2006 08:11 PM
