| | #1 |
| Junior Member Join Date: Oct 2006
| Make a SF Bassman louder!
At least that's what my friend wants from his SF Bassman AC568. Just good, clean, Fender tone for his guitar. Only louder! Any ideas?BTW, I've already rewired the bias supply and NF to BF specs. |
| | #2 |
| Senior Member Join Date: Jun 2006 Location: Southern french alps, right by the Italian border
Huh, get rid of the NFB altogether. But if it's for clean, this might not be too clever. Sell the bassman and buy a dual showman or a bassman 100/135, or a twin.
| | #3 |
| Senior Member Join Date: Sep 2006 Location: Chicago
When he says "louder" does he mean more gain? (i.e. break-up) or more "clean" headroom? If he's one of those people that actually uses a Bassman for Bass (Ugh!), he'd be MUCH better off with a Showman head (Showman's can make excellent Bass heads, depending on what kind of volume levels you're playing at. They're very CLEAN.). I can't understand why Leo named those "Bass"-man's (the LAST thing I'd want to plug into a Bassman would be a bass), whereas they sound gorgeous for guitar if your going for a nice "crunch" sound (I own FOUR Bassman heads I like their [guitar] sound so much. BTW, I'm only referring to the "Bassman Amp" models, NOT Bassman 50's, Bassman 100's or any of those series amps). Then again, if he's going for a "metal" level of break-up, he'd probably be best off getting some decent kind of O.D. pedal to "take it to the next level"
| | #4 |
| Senior Member Join Date: Jun 2006 Location: California, USA
Using more efficient speakers is one way to make it "Louder". A speaker 3dB more efficient will increase source level by the same amout as doubling the output power. You can often find speakers +6dB or more efficient than the stock one.
| | #5 |
He means more headroom..........he gets the OD with pedals.
| | #6 |
| Senior Member Join Date: Jul 2006 Location: A little town in Texas!
I once changed the output to use 2-6550 power tubes in a bassman 50 head and it sounded loud and clean. It retained the same tone but more headroom. Of course you need to mod the output to accommodate these tubes and add an extra filament supply to handle the heater voltage. Ever heard a Showman with 4-6550s ? LOUD man....... Good bass amp too.... Just a thought. SLO |
| | #7 |
I understand about the extra filament tranny....that's easily done. What do you mean, mod the output? Surely you don't mean a bigger OT? I had a BF Showman head w/2 6550A's once. I can't say it had the same tone, but it was loud and clean with a nice bottom |
| | #8 |
I didn't change the OT, I just modded the output section like a marshall 50 watt output that uses 6550's. I used the same 50 watt bassman OT and it had a bit more headroom with the 6550's. definitally would be a good amp to use in a small club jazz setup with a fender jazz bass. Thats if your not into using a stand up bass Of course using a bigger OT will get you more headroom too, even just using the 6L6 tubes. A twin OT would work but it will change the impedence of the output. I think it would then go to 8 ohm using the twin OT with just two power tubes but don't qoute me on that as I haven't done it in a long time. SLO..... |
| | #9 | |
| Junior Member Join Date: Apr 2008 Location: The Missouri Ozarks
| Quote:
| | #10 |
More headroom? The NFB resistor in the AC568 is 47K. Lower it. The earlier AA864 circuit has an 820 ohm. The Normal Channel on AC568 has an extra gain stage - the blackface AA864 does not have the extra gain stage on the Normal Channel - it goes straight to the PI and because of this (partly) is cleaner. That may lower some volume though. AL |
| | #11 | |
| Old Timer Join Date: May 2007 Location: pacific north west
| Quote:
If you want to raise amp gain in this circuit you must increase the value of the feedback resistor. Lowering the 47k feedback R in the AC568 to 820 ohms will reduce gain considerably and kill the tone. If your friend wants more headroom, I don't think changing the feedback R will help. Clean headroom is not the same exact thing as more gain. Chuck | |
| | #12 |
Whoops. Sorry I should've been more clear. Nice catch and thanks for the clarification. While I'm back here... try some other pre-amp tubes. 12AT7 etc. AL |
| | #13 |
Bassman's are known to have very "drivey" preamps (i.e. alot of gain), which is the main reason why they break-up as easily as they do. Comparing a Bassman to a [non-reverb] Bandmaster for instance (also a 2-6L6/push-pull network), Bandmasters appear to have alot more headroom (and alot less gain) to them, which is entirely due to the more moderate amount of [preamp] gain they have (IMO, the main reason why Bandmasters were never as popular as Bassman's). The later Bandmaster Reverbs, have an extra gain stage (part of the reverb network, but it affects the amp's overall gain, even if the reverb is not in use), which results in a more "drivey" response, but still not as much as the Bassman heads of the 60's..........My main point being, focus more on your preamp, not your power amp.
| | #14 |
| Senior Member Join Date: Oct 2007 Location: Tucson, AZ
...switch from 6L6GC's to 7581A's and rebias appropriately.
__________________ ...and the Devil said: "...yes, but it's a DRY heat!" |
| | #15 |
| Supporting Member Join Date: May 2006 Location: Texas USA
The AC568 is the one with the big cathode resistors on the power tubes, they gotta go. The Bassman's with the inverting output stage are not known for their guitar tone. Seriously consider rewiring the amp to blackface specs (AA864?). What is being used for speakers? Make sure the load is 4 ohms. New tubes and a cap job should be considered.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Bassman Servicing | rockgardenlove | Maintenance, Troubleshooting & Repair | 15 | 01-12-2009 08:54 PM |
| Fender Bassman 10 project | Blindog | Mods & Tweeks | 18 | 10-08-2006 03:49 PM |
| What can I make with this transformer? | jimi | Theory & Design | 14 | 09-29-2006 11:20 PM |
| 66 Bassman noises/problems? | Steve B | Maintenance, Troubleshooting & Repair | 15 | 08-17-2006 06:27 PM |
| newbie needs to make a new cab for a 2x12 blues deville | 31trum | Cabinetry | 4 | 07-06-2006 04:39 PM |
