Hi Guy's
I have recently decided to replace all the power caps in my PT60 and discovered that C57 (Seemingly an after thought by Peavey) was connected to the 500 volt side of the H.T. instead of as the schematic (Attached) shows the dropped H.T. via R79 feeding R78 & R83 V5 phase inverter plate resistors and the pre-amp pcb H.T. plus they installed a 100uf 450Volt???
Could someone throw some light on this for me? My thoughts are that someone has replaced C57 with the wrong size at some stage and also put it in the wrong part of the circuit!?
It looks like it should be connected as my drawing attached!?
Also with modern smaller same value capacitor types now availabe, perhaps I could fit C57 onto the actual power pcb?
Regards and thank you in advance
Lostfollicles
Lostfollicles
