Friends....
I picked up a Traynor YVC80 Tube Amp. This is a PROJECT amp. A previous owner bought this as a non-working amp and then went haywire and started cutting parts to measure them, ran wires where they shouldn't be... you can only imagine. Before I install tubes and attempt to run a signal through this amp, I want to start at ground zero and do some prelim checks.
This amp uses a set of 7815 and 7915 voltage regulators. Those seem to be working ok. I can see the plus and minus 15 volts.
This amp also uses an IRF830 MOSFET High Speed Switch. This was one of the parts where the legs were cut off from the PC board. I installed a new part and measure 432 vdc at the Drain, 250 vdc at the Gate, and 198 vdc at the Source. I am looking at the service manual schematic but do not see any test points to tell me if these voltages are correct. I'm also looking at a datasheet but still lost without voltage test points.
Anyone familiar with this amp or the IRF830?
Thanks, Tom
Thanks, Tom
