Does anyone on here have any recommendations for the two lengths of shielded cable I need to run in my amp build the first goes from the input jack to pin 2 of the 12ax7 (hot wire only) the shield is grounded on an earth tag of the 12ax7 valve socket bolt
The second run goes from pin 7 of the 12ax7 to the middle lug of the volume pot (hot wire only) the shield is grounded to the back of the volume pot
My main question is what is the best cable for this I have some rg174 shielded cable but I've also got an old fender guitar cable which had the plug pulled off one end and after examining the cable it looks perfect for the job could this be used? admittedly it is a lot chunkier than the rg174 but as it was a guitar signal cable to start with surely it would be perfect ?
Thanks
Scott
Thanks
Scott
