Yes. I know it well but with its typical values (250K and 4700pF) it has a much more severe behavior. An AC30 on its top boost channel of course needs it but on Plexi types it interferes excessively with their overdrive texture. In AC30s with crossline master volume it also has a variable behavior depending on the master volume setting.
I think that the conjunctive filter effect as you have described generates more complex interactions. Ideal when only a pinch of salt is needed and if the amp accepts it. I tried previously with a single ended and it didn't work well. I had to look for other formulas.
