I’ll do more reading on the subject so I don’t fry myself, I have none of the parts or anything or an amp to modify so don’t loose sleep. Thank you both for the help I’ll get back to you when I’ve got some more information.
Adding circuits to an amplifier head build
- Likes 1
Originally posted by vintagekiki View PostI understand you, do you understand the other side?
Question
- If you have carefully studied the schematics (by the way it's an 8-page in pdf), you would notice that there are more b+ (b2, b3, b4) on page 1, so it is unclear what you mean by b+
- Where you intend to run a line the b+ on your schemaic?
- If you connect all b+ (b2, b3, b4) to one point, there will not be enough filtration, the amplifier will hum and most likely go wild (oscillating)
- Don't worry about enough power (energy) for preamp, because the PT is designed to power the entire amp with 4 x 6L6GC.
- Have you read pdf pages from 5 to 8 on your schematic?
probably run it off the b2, the b2 powers all the other filaments in the pre amp stage, but there’s multiple lines off that initial b2 line, so probably just run a line like the other lines. that I read the bottom pages it’s a bunch of explanation of mods of the amp the other guy made.
also the 5v goes to the tube rectifier. The center tap is to cut down on the hum and ground that part of the transformer. You can use two 100 ohm resistors to cut the hum and ground them. and the 6.3 v go to power the filiments in the power tubes and run through the fuse and the beginning of the tube amp. Or to a foot switch or something like that.
I wouldn’t want to connect all the b+ points to one thread I just want to tap one line the to run the two circuts in series before the fx loop.
Thanks for the info ya’ll I’m diggin the teamwork on this one. I’m finally getting some answers
I get the power amp section doesn’t need to be messed with and that it will have enough power to power the amp overall.
Originally posted by vintagekiki View PostDon't worry about loose sleep, why you run away from the subject when are most interesting?
I know I got cold feet for a second, I’m finally getting answers, I knew the answers to the questions about the center tap and the 6.3 and the 5v as well I just couldn’t get them immediately. I’ve watched a bunch of videos and have that Gerald Weber tube amp video and I’ve watched it and taken notes. I get the general idea of the building and how they work and how not to get fried, that’s why I’m asking questions so I can get this thing figured out!
thank you all for your help along the way!
Viewing User Profile
There is nothing interesting there.
Everything is here (Guitar Amps)
I think vintagekiki 's comment here may be referring to the Gerald Weber videos.
Originally posted by christarak View Post
Before Nosaj or I give you any more potentially lethal advice can you please answer these questions. If you don't know, then please stop and learn. As Nosaj said, start simple.- What does the 5v tap do on your PT?
- Does your circuit use it?
- If not, why not?
- What does the 6.3v tap do on your PT?
- If not, why not?
- Does your 6.3 v wind use a CT? If so, what is it for?
- If your 6.3 wind doesn't have a CT, what else can you do to stop that horrendous hum?
- I am not even going to address the challenge of getting 20VDC from 5 or 6.3VAC.
You seem convinced to get 20v from several hundred volts in your B+. Look at the bias supply, just above the power transformer.. Page 3. MAy I suggest just duplicating that circuit, from the same tap, except reverse the polarities. Reverse the rectifier, and invert the filter caps. Why start with 400v when all you need is 20?Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostYou seem convinced to get 20v from several hundred volts in your B+. Look at the bias supply, just above the power transformer.. Page 3. MAy I suggest just duplicating that circuit, from the same tap, except reverse the polarities. Reverse the rectifier, and invert the filter caps. Why start with 400v when all you need is 20?
make the same bias circut
but flip the caps so the negative lead is on the positive side
what do you mean reverse the rectifier? Like the rectifier for the entire amp?
and how do you reverse the polarities? Thanks for the info!
At the tap for the bias supply, we add another diode but facing the other way - so it make positive instead of negative supply. D10 is the rectifier diode for the bias supply. Our new diode would be wired reverse of that. Yes, the caps would be wired reverse of what we see in the bias supply
the negative lead is on the positive sideEducation is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostAt the tap for the bias supply, we add another diode but facing the other way - so it make positive instead of negative supply. D10 is the rectifier diode for the bias supply. Our new diode would be wired reverse of that. Yes, the caps would be wired reverse of what we see in the bias supply
We wouldn't state it that way, it is confusing. I would use terms like connect negative side of cap to ground.
that seems easy enough.
why reverse the polarities and the caps? What does this do?
Also you are correct I need around 20 volts, are the bias supplies usually 20 volts ish? Or around there? How do you know it’s the amount I need when there’s nothing that says the voltage on that part of the schematic?
much appreciated! Thank you for answering my questions I appreciate it very much.
Originally posted by Shrimpfarmer89 View Postwhy reverse the polarities and the caps? What does this do?
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
The bias supply is like maybe 60v, but that is a detail, we can adjust with a resistor or two. Just way better - in my view - to come down from 60 than 400.Education is what you're left with after you have forgotten what you have learned.
