I have a set of JJ 6V6S in my current 5E3 build that are dissipating 14.3 watts with a cathode voltage of 22v and plate to grid voltage of 349v. 268 ohm cathode resistor. The JJs went microphonic after about an hour of dubbing around with them, so I sent them back to AES for another set. I had planned on trying the zener diode trick to drop the B+ down 10 volts or so to get things within maximum dissipation of 14 watts for a JJ. Before doing this, I tried a couple of other used sets and got 12.8 watts and 13.5 watts respectively. So this got me to thinking, is it possible to request a set that will draw less idle current vs more, from the matching numbers on the box? Something like, "this amp runs hot, so please give me some cooler tubes"? Does it work this way, and if so, how?
Thanks.
Thanks.
